Home > Message Board > Press Releases > Archive through 2008 > Archive through August 12, 2008 > TV One LM-1750HD LCD Colour Monitor Announced
TV One displays the new high performance multi-format LCD monitor for the broadcast and professional market at the IBC 2008 Exhibition in Amsterdam next month. Multiple analog and digital video sources can be viewed on the new LM-1750HD and with its high brightness, wide viewing angle, excellent contrast ratio and high definition colour, outstanding images can be monitored.
The six inputs can accommodate SD/HD-SDI (with an active output), HDMI, Analog RGBHV, YUV or YPbPr Component Video and 2x Composite Video. A YC (S-Video) input can also be used in lieu of one of the Composite Video inputs if desired and both PAL and NTSC television standards are supported and automatically detected. Stereo Audio monitoring is also available using the five Stereo inputs and dual internal speakers, driven by a 3 watt amplifier.
Contrast, brightness, sharpness, colour, hue, black stretch and other parameter necessary for optimum monitor performance can be adjusted via the menu system and on-screen display. The menu language is also selectable between English, French, German and Portuguese. A Sync Delay mode allows viewing of the vertical/horizontal sync as well as the vertical blanking intervals and a Blue Only mode allows accurate setup when viewing colour bars.
The metal case has a standard VESA mount on the rear panel and a rackmount kit is also included that can tilt up or down allowing full viewing even is the monitor is mounted considerably above or below normal eye level.
The LM-1750HD LCD Colour Monitor is available to order now and has a recommended retail price of £2010 (€2605).
This amazing new monitor, along with the entire TV One product line, can be viewed at the up-coming IBC 2008 Exhibition being held in Amsterdam next month on the TV One Stand 3.C41. Alternatively more information can be found on the TV One website www.tvone.eu.
