Home > Message Board > Press Releases > Archive through 2008 > Archive through August 28, 2008 > SoundSense Announces NoiseOut Acoustic Speaker Back
SoundSense Solves In-Wall and In-Ceiling Speaker Noise Problems With NoiseOut™ Acoustic Speaker Back While Enhancing Installed Speakers Performance
SoundSense will feature and demonstrate its patent-pending new NoiseOut Acoustic Speaker Back in booth #453 at the CEDIA Expo 2008. These high-performance acoustic enclosures are engineered to maximize the performance of recessed speakers while virtually eliminating noise problems in adjacent environments. Designed with the installer in mind, the NoiseOut Acoustic Speaker Back comes as a single unit, completely constructed and ready for installation. Due to the flexibility of the material, the speaker backs can easily be used in both new construction and retrofit applications. NoiseOut Acoustic Speaker Backs are available in two standard sizes, addressing both ceiling and wall applications. Custom enclosures can also be ordered to fit any speaker size.
“The new NoiseOut Acoustic Speaker Back is an essential product for every high-performance speaker installation where the quality of sound reproduction matters,” says Bonnie Schnitta, SoundSense LLC president. “This product solves adjacent environment noise problems while improving the sound quality of the speakers all at the same time.”
The NoiseOut Acoustic Speaker Back was developed to reduce noise transmission through speakers in walls and ceilings, keeping the “noise out” of adjacent rooms. The materials used to create the speaker backs are acoustically tested to significantly reduce noise transmission between walls and floors.
About SoundSense
SoundSense, LLC is a turnkey acoustical engineering design firm. SoundSense founder and President, Dr. Bonnie Schnitta, is at the forefront of breakthrough technology to encourage awareness of acoustics and development of unique products to reduce noise and create a soothing and peaceful acoustic environment.
