Home > Message Board > Press Releases > Archive through 2008 > Archive through September 09, 2008 > Sanus VisionMount LT25 Revolutionizes the Flat-panel TV Industry
Featuring the industry’s most innovative post-installation adjustment technology and lightweight wall-plate design
(ST. PAUL, Minn.) – Sanus Systems has engineered a new wall mount that revolutionizes the flat-panel TV industry. The VisionMount LT25 Tilting Wall Mount offers the most advanced post-installation adjustment technology available; a new lightweight aluminum and ABS wall-plate design with a strength-to-weight ratio and corrosion resistance greater than steel; and easier installation.
“Sanus revolutionized the flat-panel TV industry with the VMPL, the very first universal wall mount, and now we’ve done it again with the LT25,” said Keith Pribyl, vice president for consumer sales. “We are very excited to have introduced the LT25 with a number of innovative features and design qualities that are really focused on making installation easy and reducing the amount of time it takes to install the mount,” Pribyl added. “With the LT25, installers can create the perfect TV display in any home theater setting.”
Durable Construction
The LT25 introduces an innovative wall-plate design constructed from lightweight, 6000-series extruded aluminum alloy rails and high-grade ABS decorative end caps. Extruded aluminum offers a strength-to-weight ratio and corrosion resistance much greater than roll-formed steel, and the ABS end caps, with their sleek surface finish, provide an aesthetically pleasing look from the sides of the mount.
The LT25 wall plate weighs only 3.5 lbs., 68 percent less than the VMPL wall plate, so it’s easier for one person to balance and install the mount. And because the mount is lighter, it reduces material waste and packaging material, and costs less to transport.
Innovative Features
Aluminum is a very versatile material that can be extruded into complex geometric shapes, making the end product both functional and attractive. The LT25 wall plate offers a unique design that allows for greater compatibility for future ClickFit™ add-on accessories, including solutions for mounting sound bars, center-channel speaker and side speakers.
The open architecture of the wall plate provides ample space for cable management and electrical boxes.
Unprecedented Technology
The LT25 also offers many incredible technology features.
• ProSet™ post-installation height and leveling adjustment ensures the TV is perfectly positioned.
• Virtual Axis™ fingertip tilt technology offers effortless viewing angle adjustment without the use of tools.
• ClickStand™ props hold the bottom of the TV an additional 3.75 inches from the wall, enabling the installer to easily access cables, then click securely back onto the wall.
• ClickFit™ allows accessories such as surge suppressors to snap onto the wall plate and remain hidden behind the TV.
The LT25 supports large flat-panel TVs from 30 to 60 inches and up to 175 lbs. It is currently available in black and silver and lists for $219.99 USD.
About Sanus Systems
Sanus Systems, a division of Milestone AV Technologies, designs and builds a broad variety of audio video mounts, furnishings and accessories that will satisfy even the most demanding audio/video enthusiast or interior designer. Every Sanus product is engineered to enhance AV systems and the surrounding décor. Today Sanus offers more than 300 products, including on-wall furniture, home theater furniture, TV stands, audio racks, wall mounts and speaker supports. Sanus products are available at thousands of retail locations nationwide; a store locator is available at www.sanus.com.
http://www.sanus.com/us/en/products/ProductDetails/line/visionmount/pcat/tilting Mounts/modelCode/LT25/
