Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through September 30, 2008 >
Hear the Difference with SpeakerLUX, Wireworks Best-Selling Speaker Cabling, ...
Hear the Difference with SpeakerLUX, Wireworks Best-Selling Speaker Cabling, at AES 2008
| Posted by Nicole Smith on Tuesday, September 30, 2008 - 01:06 pm: |
SpeakerLUX is a super-flexible loudspeaker cable with 49 strand 13-gauge bare copper, available in two, four, six and eight conductors and provides efficient signal delivery. Featuring an ultra-flexible PV black satin finish and a pressure extruded jacket, SpeakerLUX produces a lay-flat cable and eliminates the need for inconvenient plastic or string fillers. SpeakerLUX makes the termination process easy without having to worry about loosing strands while the jacket is being stripped.
Color-coded insulation makes identification easy. If additional copper is necessary for high-powered low-frequency systems, doubling up on conductors solves the problem. The tough but flexible jacket is pressure filled, eliminating the need for fillers, and stabilizes the conductors. SpeakerLUX is also sized to match Neutrik’s SpeakOn connectors.
“SpeakerLUX is designed to be tough and durable, while also flexible, making it the ideal speaker cable for live performance and in-studio applications,” states Gerald Krulewicz, president of Wireworks. “SpeakerLUX is top-of the-line quality without the top-of-the-line prices typically associated with high-end speaker cabling.”
SpeakerLUX is part of Wireworks award-winning WireLUX family of flexible audio cables, which also includes MusiLUX, the ultimate in microphone cabling, InstaLUX, a color-coded installation cable that is also available in 10 colors; StudiLUX, a fast-strip multi-channel interconnect cable and UltraLUX, a multi-pair oxygen free studio cable.
All WireLUX products provide superior sound quality with maximum cable flexibility to audio professionals by offering several variations of cables for specific uses. Each cable has been designed and manufactured for an individual need, while the entire line shares the same high-quality workmanship and dependability for which Wireworks products are known for.
About Wireworks
Headquartered in Hillside, NJ, Wireworks is the pioneer in professional audio/video cabling products, creating the industry over 30 years ago. Wireworks manufactured the first multi-channel audio cables and the first multi-pin interconnect system, establishing standards that are still in use today. The company also introduced the first colored microphone cables, the first mixed audio/video multi-pin interconnect system, and the first and only multi-pin connector system that can accommodate audio, video, data, and control signals in a simple, easy-to-use connector.
From Broadway to broadcast, theatres, auditoriums, arenas, corporate boardrooms, operating rooms and houses of worship installations, Wireworks remains the leader in audio/video cabling systems, microphone splitters and interface panels, continuing to set standards through its inventive products. Wireworks takes pride in its innovative designs and its personalized customer service. For more information, visit www.wireworks.com or call 1-800-642-9473.
