Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through November 19, 2008 >
OrionGadgets introduces Samsung Instinct chargers and cradles
| Posted by Dennis Sloutsky on Tuesday, November 11, 2008 - 06:57 pm: |
OrionGadgets Samsung Instinct USB sync & charge cradle allows you to synchronize and charge your Samsung Instinct with any USB-enabled computer. It provides easy and convenient desktop access and display, allowing you to place your Samsung Instinct at a comfortable reading angle while it is being charged or synchronized with your computer. This cradle additionally comes with an AC adapter that allows you to charge your device from a standard wall outlet when no computer USB port is available. The standard version of OrionGadgets Samsung Instinct USB sync & charge cradle retails for $25.00, while a more advanced version that allows you to charge a second battery at the same time as you are charging your Samsung Instinct device retails for $27.00.
OrionGadgets Samsung Instinct sync & charge USB cable is compact and lightweight, making it the perfect choice for travelers. It allows you to synchronize and charge your Samsung Instinct with any USB-enabled PC or Mac computer. OrionGadgets Samsung Instinct sync & charge USB cable retails for $10.00.
OrionGadgets Samsung Instinct retractable sync & charge USB cable is perfectly suited for travel: with its dual sync and charge capability and innovative practical space-saving design it allows you to synchronize and charge your Samsung Instinct with any USB-enabled PC or Mac computer. Its retractable design allows you to save space when you are on the move. OrionGadgets Samsung Instinct retractable sync & charge USB cable retails for $14.00.
OrionGadgets Samsung Instinct car charger plugs into the cigarette lighter in your car, supplying your Samsung Instinct with power while charging the battery at the same time. Its cable retains its original shape even after extended periods of use. OrionGadgets Samsung Instinct car charger retails for $10.00.
OrionGadgets Samsung Instinct retractable multicharger USB travel kit allows you to synchronize and charge your Samsung Instinct whether you are in your car or at home. This USB travel kit features an OrionGadgets retractable sync & charge USB cable coupled with an OrionGadgets AC & car adapter, which allows you to charge your Samsung Instinct using your computer's USB port, electricity wall outlet or your car's cigarette lighter. It means that you will only need one charger for your Samsung Instinct wherever you go. This kit is compatible with both European and North American wall outlets, as it supports voltage input of 100V to 220V. OrionGadgets Samsung Instinct retractable multicharger USB travel kit retails for $16.00.
OrionGadgets Samsung Instinct cradles and chargers are now available from http://www.oriongadgets.com/samsung-instinct-m800-accessories. All OrionGadgets accessories come with free shipping in North America and a 30 days money back guarantee.
About OrionGadgets
OrionGadgets is a manufacturer and a retailer tailored to individual consumers as well as small to medium-sized businesses, providing innovative accessories products for mobile phones, PDA, PMP, and portable gaming devices. OrionGadgets strives for 100% customer satisfaction.
