Home > Message Board > Press Releases > Archive through 2008 > Archive through November 19, 2008 > Crestron Announces Satellite Radio Antenna Solutions
ROCKLEIGH, NEW JERSEY – Crestron introduces versatile antenna packages that simplify installation and distribution of multi-room satellite radio. Just one Crestron outdoor antenna can feed up to 16 Crestron XM or SIRIUS® satellite radio tuners, and these new satellite antenna solutions enable the distribution of satellite radio channels to multiple receivers throughout the home and office using standard RG-6 cable.
The high-performance Crestron antenna features a considerably narrower beam as compared to standard consumer antennas, achieving a significantly higher signal-to-noise ratio. Additional front-end filtering blocks interference from nearby out-of-band RF signal sources such as Wi-Fi, cellular and cordless telephones.
For easy ordering and installing Crestron offers the following four satellite radio antenna packaged solutions:
SRD-ANT-1-PAK supports a single tuner; range up to 200 feet
SRD-ANT-4-PAK supports up to four independent tuners; range of up to 200 feet each
SRD-ANT-1LD-PAK includes one tuner and high-gain line amplifier; range of up to 350 feet
SRD-ANT-8-PAK (includes two 4-way amplified splitters) supports up to eight tuners: signal range up to 300 feet. An additional 3-way couple can split the antenna signal to each of the two amplified splitters, allowing easy expansion up to a total of 16 satellite radio tuners.
The basic kit for each package includes a wall mount bracket, pole mount hardware, F-to SMB adapter cable(s), and weatherproof boot. The 4-PAK features the 4-way splitter and attenuator, and the 8-PAK adds a line amplifier, 4-way coupler, 2 4-way amplified splitters, and attenuators.
For more information about Crestron Satellite Radio Antennas go to www.crestron.com. For high-resolutions photos go to www.crestron.com/pressroom.
