Home > Message Board > Press Releases > Archive through 2008 > Archive through December 06, 2008 > Pragmatic MCA-1248 12-channel Amplifier
High Efficiency, Audiophile Quality, 2U, 12-Channel Multi Zone Amplifier Delivers in Both Quality and Quantity. Efficiency So Great That a Heat-Sink and Cooling Fan are not Required
Pragmatic Communication Systems, Inc. has always made it its mission to introduce energy efficient and compact products into the market. There is no better example of that philosophy than the MCA-1248, a 12-channel audiophile quality amplifier. The MCA-1248 multi-channel amplifier produces a big, luxurious sound yet is so efficient that it doesn't require a heat sink or ventilating fan. The small yet powerful package delivers a true high fidelity performance that surpasses the quality of amplifiers ten times its size and weight. At only ten pounds and a two-rack unit height, it is by far the most compact and efficient amplifier in its class.
MCA-1248
In fact, MCA-1248's biggest competitor weighs in at a whopping 72 pounds. Its staggering weight is due, in part, because it loses large amounts of energy to heat. In order to contain the heat, the amplifier must have more aluminum in its heat sink. In addition, it also contains more copper, sheet metal and iron. So not only will the competitor's amplifier cost you more on energy bills, but you will also squander money away in its hardware.
The robust design of the MCA-1248 provides extremely clean, state-of-the-art power. It produces unexpected sound depth and musical clarity. The unit accepts any volume controlled line level input and uses a quiet and efficient 110 V AC power supply. It also features advanced protection circuitry guards against system damage from overload, overheating or short circuits.
There are a number of applications for the MCA-1248. It is ideal for multi-room audio, bi-amplified speakers and home theater systems. It can power six rooms with ease and produces a signal-to-noise ratio and dynamic range of greater than 100 dB. It maintains continuous power of 48 watts per channel with peak power of 90 watts per channel.
Pragmatic offers high quality digital amplifiers that possess numerous advantages over other options in the market. A Pragmatic amplifier boasts high efficiency and clock frequency. It also has very linear gain and phase characteristics with a flat frequency response from 20 Hz to 20 kHz. There is no ripple in the pass band and very low change in distortion versus out power levels (usually between 0.01 and 0.05%). It maintains very low and uniform distortion on all frequencies and very high signal-to-noise ratio and dynamic range.
Pragmatic Communications Systems, Inc. is a Silicon Valley based company established in 1994 to design, develop and produce a variety of innovative products for wireless audio, video and data communications. The majority of the company's products up until 1997 were designed for industrial and commercial applications, after which Pragmatic branched into the consumer market. The success of the older products led to a strong and dynamic technology base, which helps fulfill Pragmatic’s mission to use its technologies to provide solutions to long unresolved technical problems with designs that are both compact and energy efficient. This belief has been applied to a new generation of Pragmatic products such as DMS™, CATS™, True Music™ wireless hi-fi system, and True View™ wireless video system.
