Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through December 06, 2008 >
Bel Canto USB Link 24/96 Debuts
| Posted by Scull Commun... on Monday, December 01, 2008 - 09:58 pm: | + Share | Create New | Reply | Edit |
For Immediate Release
Introducing the Bel Canto USB Link 24/96
Opens a High Performance Audio Link From Any Computer
Plays Music Files Up To 24 bit 96kHz
Visit Us at CES 09 Venetian Tower 29-232
Minneapolis MN • December 1st, 2008 • Bel Canto Design, Ltd., manufacturers of analog and digital source components and amplifiers debuts the USB Link 24/96, the must-have component for computer hard disc music systems.
We all know what audiophiles want: Take what’s there and make it better. At the last Rocky Mountain Audio Fest a number of rooms played high resolution music from hard disc, like Bel Canto and Joseph Audio. The sound system in both rooms – totally amazing of course – featured the new Bel Canto USB Link 24/96.
This timely device converts a computer-derived USB input of up to 24 bits and 96kHz to SPDIF and outputs the signal on a 75 ohm BNC. The USB Link 24/96 includes a Stereovox SV2 BNC/BNC cable with RCA adaptor to feed your audiophile DAC of choice – most likely a Bel Canto DAC3! Significantly improves the sound of your 16-bit 441.kHz music files as well!
Convenient Audiophile Features
• Converts USB computer-sourced files to SPDIF output
• Compatible with native drivers on Mac and Windows
• Accepts high-resolution audio files with data rates up to 24 bits and 96KHz
• Quality Stereovox XV2 BNC/BNC with RCA adaptor connects to any quality DAC
• USB Link 24/96 disables system volume control
• Low-jitter clock recovery features reference crystal oscillator
• Self-powered via USB input benefiting from LC filters and low-noise local regulation
• Galvanic isolation between computer and audio system prevents high-frequency noise from polluting signal
MSRP: $495
Includes Stereovox XV2 BNC/BNC SPDIF cable with RCA Adaptor
A Snap to Set Up
Simply connect a type-B USB cable from computer to the USB input on the Link; a red LED indicates power. Your MAC or PC automatically recognizes the unit as Bel Canto 2496 USB in the Sounds and Audio Devices control panel. Connect the supplied Stereovox XV2 cable between the USB Link into either a RCA or BNC SPDIF DAC input with the handy adaptor provided and you’re ready to rip! Pardon our enthusiasm; you’re ready to play high quality music from your computer!
Bel Canto music products merge artfully with your lifestyle, your music, and your audiophile passions. They’re compact, sleek and hip enough to flatter any room. Designer John Stronczer uses less power to do more with elegant, efficient designs that always get you closer… to the experience.
Bel Canto Design has developed award-winning products for more than 15 years via the highest standards of design, engineering and production practices. Included in the Bel Canto line are a series of CD players, DACs, integrated amps, mono and two-channel amplifiers, plus the e.One Pre3 stereo analog preamp with balanced I/O and the PHONO3 featuring adjustable cartridge loading.
Bel Canto
Get Closer… to the Experience
Contact
Bel Canto Design, Ltd. • 221 North 1st Street • Minneapolis MN 55401 • USA
Tel: 612-317-4550 (9AM to 5 PM CST M-F) • Toll-free (866) 200-7342
Fax: 612-359-9358 • www.belcantodesign.com • mm@belcantodesign.com
Press Contact • Reviews • Images
Scull Communications • 212.807.0519
jscull@scullcommunications.com • www.scullcommunications.com
Images and press releases • www.scullcommunications.com/pressresources.html
