Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through December 23, 2008 >
Logitech Comfort Lapdesk for Notebooks
| Posted by Admin on Tuesday, December 09, 2008 - 05:37 am: |
"While other lapdesks promise improved comfort, they often fall short because of poor design and low-quality materials," said Denis Pavillard, Logitech's vice president of product marketing for keyboards and desktops. "The new Logitech lapdesk has a thoughtful design that will help make your laptop experience more comfortable, wherever you use your computer."
Logitech research revealed that nearly 60 percent of people who use a laptop at home use it on the couch so they can be with their families while browsing the Web, e-mailing or chatting. In addition, the research showed that 36 percent use a laptop on the bed and 16 percent use it while sitting or lying on the floor. However, nearly 50 percent of those people report concerns about laptop heat and 41 percent raise concerns about posture. Some people use a pillow or book in an attempt to provide a barrier to the heat emitted from the laptop, but those solutions often end up trapping heat, making it even hotter.
Unlike makeshift solutions and other lapdesks, the Comfort Lapdesk features a four-layer, heat-shielding design. The bottom-layer's fabric and an air-flow chamber between the lapdesk's base and top combine to further minimize heat. Plus, instead of the whole laptop lying flat against the body, the arched base makes contact with the legs in just four places, improving air flow.
To provide a stable foundation for comfortable laptop use, the cushioned base allows people to relax their legs instead of locking the knees together to support the computer. In addition, a non-slip glossy finish on the top of the lapdesk helps prevent the computer from sliding around. And a 12-degree angled riser positions the notebook to a height that supports neck and leg comfort (when used in a seated position).
When you're done using the computer, the lapdesk's thin, streamlined profile makes it easy to slide under a couch or bed, or it can stand upright for storage next to the sofa.
Pricing and Availability
The Logitech Comfort Lapdesk for Notebooks is expected to be available in Europe in January and in the U.S. in February for a suggested retail price of $39.99 (U.S.).
