Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through December 23, 2008 >
HAI Power Hub Ships
HAI Power Hub Ships
| Posted by Theresa Bres... on Wednesday, December 10, 2008 - 02:52 pm: |
HAI Now Shipping Power Hub for New Access Control Line and General Purpose Power Supply
HAI (Home Automation, Inc.), leading manufacturer of integrated automation and security products since 1985, is now shipping the HAI Power Hub, a digital high efficiency power source engineered to meet the forthcoming ENERGY STAR requirements for power supplies and battery backups. It comes in two versions; the 83A00-1 is a Power Hub in an enclosure and the 83A00-2 is a Power Hub on a Universal Mounting Plate. It is designed to provide power to several HAI products, including the HAI Access Control Readers with electric or magnetic locks, Omni Consoles, OmniTouch 5.7 Touchscreens, and many other devices. It is a 12VDC power supply that is mounted in an enclosure. The HAI Power Hub is compatible with both 120/60Hz and 220V/50Hz for International applications.The HAI Power Hub has convenient connections and power terminals for a neat installation. It is designed to eliminate unsightly transformers, power strips, external power supplies, battery backup units, and complex wiring normally associated with access control installations. It connects up to 8 Access Control Readers to the HAI controller. Two of the Power Hubs may be connected together to connect up to 16 readers to an OmniPro II or Lumina Pro system.
HAI products are available through a worldwide network of Distributors and installing dealers. For more information regarding the new HAI Power Hub or other HAI products, please visit www.homeauto.com or call 800-229-7256.
To download a high res photo of the 83A00-1 Power Hub in Enclosure, please click here: http://www.homeauto.com/mediacenter/HaiPRImage.asp?image=83A00-1.jpg
About HAI (www.homeauto.com): HAI (Home Automation, Inc.) is a privately held manufacturer of integrated automation and security products for residential and commercial use based in New Orleans, LA. Incorporated in 1985, HAI has developed a full line of award-winning automation products, including home control systems, programmable communicating thermostats, smart light switches, Whole Home Audio systems, video surveillance equipment, Touchscreen interfaces, and software that allows access and control of an automation system over the Internet. All products are sold through HAI’s worldwide network of Distribution Partners and installed by trained dealers in over 80 countries.
Moderator
Username: AdminPost Number: 4849
| Posted on Wednesday, December 10, 2008 - 04:14 pm: |
