Home > Message Board > Press Releases > Archive through 2008 > Archive through December 23, 2008 > Induction Dynamics S1C1.iw and ID1.iw In-Wall Loudspeakers
New products provide high performance, eliminate need for center speaker.
Induction Dynamics®, an Overland Park, Kansas based audio company, has introduced the S1C1.iw and ID1.iw loudspeakers. Designed for in-wall or on-wall mounting, these loudspeakers offer easy installation and outstanding sonic quality. They will be on display at CES booth # 20422.
The ID1.iw features a three-way speaker plus dual 10" subwoofers. The subwoofers are located in dedicated back boxes, with the woofer, tweeter and mid-range driver in their own cabinet. The lightweight back boxes come as one piece and can mount directly into the wall or on the wall using Induction Dynamics' low-profile, custom painted B1 box. Once the back box assembly has been installed, the speaker's one piece baffle with pre-installed drivers is simply bolted to the front.
The S1C1.iw solves the problem of locating a center channel loudspeaker so that the sound is coming from the proper spot. With many center loudspeaker installations, the users are forced to place the speaker too high or too low in the room, making dialogue sound like it is coming from the wrong location. The S1C1.iw comprises two loudspeakers, with the top half acting as a standard right or left channel and the bottom half as the center. When the lower halves of two S1C1.iw speakers are wired in parallel, center channel sound effectively comes directly from the viewing screen, right at ear level. As with the ID1.iw, this product can be mounted in-wall or on-wall.
ID1.iwS1C1.iw
ID1.iwS1C1.iw
"These products were developed in response to customer requests for larger and more versatile in-wall speaker systems," said Chris Combest, CEO of MSE Audio Group. "With these speakers' multiple functions, easy installation and attractive styling, they are certain to please even the most discriminating of listeners."
About Induction Dynamics
Induction Dynamics was founded in 1995 and is part of MSE Audio Group. Induction Dynamics' headquarters, manufacturing and distribution facilities are located in Overland Park, Kansas. Induction Dynamics designs and builds high-end loudspeakers with only the most select components and materials and utilizes numerous unique and proven technologies including exclusive, patented S4X™ driver-control technology, Wide Angle™ phase alignment, and patented grille frames, fastener designs, corner mounts, stud grabber in-wall systems, and excursion-limiter technology. Induction Dynamics' extensive line of high-end loudspeakers and the patented SolidDrive® sound transducer are available through a nationwide network of authorized dealers. www.inductiondynamics.com. (866) 663-9770
