Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through January 06, 2009 >
Peachtree Audio Nova Integrated Amplifier
| Posted by David Solomon on Tuesday, December 30, 2008 - 12:36 pm: |
Computer Audio is here to stay so let's make it sound right!
The Peachtree Audio Nova is a world class 80wpc integrated amplifier with enough digital and analog inputs and outputs to satisfy all the new digital devices, plus, it can handle a few of the old dogs like turntables (w/external phono preamp), tuners, etc.. It performs much like a high-end integrated amplifier because that's what it is.
The pre-amp section employs a 6922 tube with a Class A output stage. This maintains a high level of detail while taming harsh compressed digital music. We couple that with an A/B amplifier in the final stage to achieve a very analog sounding product. The Nova has a USB input for your computer in addition to 2 coax, and 2 optical inputs for other digital sources like Squeezebox, Apple TV, Wadia iTransport, Airport, Sonos, and XM or Sirius tuners. It also has 3 analog inputs for docking stations, CD players, tape decks or phono preamps. If you want to add a subwoofer or outboard amplifier, the Nova features a "Class A" variable preamp-output and a fixed line output. Nova covers all the bases like no other product before it.
Digital to Analog converter: Maybe the most unique Nova feature is the onboard ESS 9006 Sabre DAC. It's a 24/96 upsampling D/A converter which transforms just about any digital source to the performance of a high-end CD player. The ESS Sabre DAC's patented jitter reduction circuit re-clocks the digital signal to an unmeasureable levelbefore passing it through a high-resolution 24/96 upsampling processor that's also capable of 122dB s/n ratio. This is unheard of in any D/A converter until now and out-specs anything from any other DAC on the market. But the DAC chip is only part of the story because the surrounding electronics are extremely important. We employ 11 regulated power supplies for the DAC and transformer-couple each digital input stage so noise associated with ground problems and switching power supplies is eliminated. The USB connection is s galvanically isolated from the computer connection. This is important because significant noise generated by the computer's CPU and switching power supplies travels down the USB ground and manifests itself as a major source of jitter. We eliminate it all before the DAC sees it. We know of no D/A converter on the market at any price that will better the Nova ESS D/A converter in bench tests and to our ears. To match the performance of the D/A alone would be much more expensive than the price of the entire Nova. These are lofty claims, but can be backed up by the technical measurements and listening tests.
Use the Nova as a D/A converter in your current system. If you're thinking about adding a high-end D/A converter to your current system, you would serve yourself well to audition the Nova first. The Nova features a Class A fixed line out so it can be used as a "remote switchable D/A converter" that can be added to any local or whole-house audio system to handle and improve any digital source. It's also a great way to add a PC or Mac Mini to your existing system.
Home Theater Bypass: The 3rd analog input doubles as a "Home Theater Bypas" so you can have the best of Home Theater and 2-channel in the same system. Simply take the left and right "pre out" from your receiver or processor and connect to the "Home Theater" bypass on the Nova. A selector switch on the back panel converts from Aux to HT bypass. In this application your receiver transparently uses the L&R amplifier section of the Nova, leaving the HT receiver amplifier to push only the center and rear speakers. One, this leaves the receiver responsible only for pushing the center and rear speakers, making the receiver much more efficient and less taxed. And two, when you listen to a 2 channel source plugged directly into the Nova, there's a straight line from the source to the Nova to the speakers -- no processing, no running the signal through a forest of circuitry. This leaves little between the music and your ears. If you're a 2 channel fan, it's the only way to do a theater right.
For the headphone user, the Nova has a "Class A, tube" headphone section that rivals some of the best Headphone amps available today. When the headphones are plugged in, the speakers are muted so you can rock on when quiet is a necessity. Headphones have never sounded better than through the Nova.
Whether it's digital or analog, the Nova will make it sound great! Along with its little brother, the Decco, they're truly the most versatile integrated amplifiers on the market and engineered for the way you listen today.
Now all the time, effort, and money you've spent ripping CDs and downloading music is rewarded with truly incredible sound. Even compressed MP3 files sound almost indistinguishable from the original CD when played through the Nova or Decco. So if you like to rip or download -- go for it. We'll make it sound great.
The Nova will arrive in January 09 and available for purchase online and at 150 locations around the USA for audition.
- 5 digital input 24/96 ESS Sabre D/A converter: USB/Toslink/SPDIF digital inputs
- Decodes mp3, mp4, flac, AFF, wav, Apple lossless, plus all others
- Tube pre-amp section,
- 80 watt per channel high current A/B amplifier
- 3 analog inputs/1 input doubles as a Home Theater Bypass
- Tube headphone output(Class A)
- Detachable power cord
- Multi voltage switchable toridal power transformer
- Class A Preamp Stereo output for additional amplifier or subwoofer
- Remote control
- Slot in back to hide Sonos ZP80/90
- 15"W x 5"H x 14"D, 22lbs out of box, 29 lbs in box
- Finishes: Black Gloss, Cherry, Rosewood
- UMRP $1,199 in Piano Black, Rosewood, and Cherry.
Old scool meets new school, and hey, they really like each other...
CES Jan 8-11
Venetian Hotel Suite 30-106
Contact: David Solomon, 770-649-9544
