Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through January 06, 2009 >
Gefen Announces Audio Solutions to Maximize Systems at Macworld
| Posted by Linda Morgan on Tuesday, January 06, 2009 - 10:10 am: |
GefenTV is also showing a 2x1 Digital Audio Switcher, which allows you to connect two CD players, DVD players or computer audio systems to one A/V receiver using the TOSlink format. Users switch between both digital audio sources using the tiny switch on the Switcher. For added convenience, all three digital audio devices (two sources; one receiver) may be connected up to 25-feet in distance using standard TOSlink cables.
The GefenTV 1:2 Digital Audio Splitter streamlines audio systems by allowing one CD player, computer system or DVD player to deliver audio to two different A/V receivers at the same time. This tiny solution accepts one digital audio signal in TOSlink format and delivers two TOSlink outputs. For multi-zone audio environments, this is the perfect solution. One audio input and two digital audio outputs can be connected up to 16-feet in distance for flexibility in system set-up.
About Gefen:
A leader in the high definition digital domain, Gefen provides advanced solutions for Macintosh users that extend, integrate, optimize, distribute and convert HD and PC signals to maximize system functionality. The GefenTV brand offers pro-quality engineering streamlined for consumers. Gefen’s add-on solutions enhance computer systems by allowing them to operate beyond their original capabilities. A selection of high quality cables complements the product line. Visit www.gefen.com for detailed product information.
