Home > Message Board > Press Releases > Archive through January 13, 2009 > VEXO Audio Advanced Vacuum Tube Power Amplifiers
+ Share | Create New | Reply | Edit
Superb Design and Build Quality Help VX PP-KT88/C and VX SE-KT88/C Amps Deliver Dynamic, Crystal-Clear, Emotionally Engaging Audio
Koetsu USA, the U.S. distribution arm of the world-renowned Japanese cartridge manufacturer, introduces into the U.S. market the VX PP-KT88/C Push-Pull Stereo Power Amplifier and the VX SE-KT88/C Single-Ended Stereo Power Amplifier at the 2009 International Consumer Electronics Show, beginning here today.
VEXO produces superb vacuum tube amplifiers and preamplifiers characterized by refined, exclusive designs, and exceptional build quality and performance. Its products employ the best valves on the market -- by Svetlana, Tesla JJ, National and Electro-Harmonix, among others -- guaranteeing reliability and the reproduction of audio at well-defined sound levels with crystal-clear fidelity, high dynamics and a wealth of micro-details. VEXO designs generate a wide, structured, realistic image with the emotional impact of a live rock concert or a symphony orchestra.
Vexo
VEXO’s VX PP-KT88/C Push-Pull Stereo Power Amplifier drives 45 Watts for each of two channels, while the VX SE-KT88/C Single-Ended Push-Pull Stereo Power Amplifier drives 15 Watts/channel. Designed with Class A single-ended, ultra-linear configurations, both amplifiers use transformers with grain-oriented cores and multilayer windings for the output stage. FIXED BIAS polarization supplies a negative voltage to the control grid, allowing the accurate, independent adjustment of every valve’s bias current to set the best operating point. A BIAS BOARD on each amplifier’s rear panel makes it easy to conduct control and adjustments without disconnecting or moving the equipment.
Each amplifier’s power section includes one very low-leakage flux toroidal transformer and self-standing LRC filters for the left/right channels. The amplifiers’ unusually strong frame is the result of a harmonious blend of advanced production processes, such as laser-cut metal sheets with a minimum thickness of 15/10, and traditional processes, such as manually finishing stainless steel elements to a mirror-like sheen. Sturdy support bases incorporate anti-vibration elements to minimize disturbances, and a removable matte-black safety guard. A pair of ALPS, blue series L/R potentiometers on the front of each model allows simultaneous control of the volume and the balancing. The combination of the potentiometers and a CD/TUNER/AUX input selector make the each amplifier a complete component, with no need for accessories.
VEXO’s additional vacuum tube components include the VX PP-EL34/C, VX PP-KT88 and VX PP-EL34 Push-Pull Stereo Power Amplifiers, the VXS40 Power Amplifier, the VX PRA01 Class A Stereo Preamplifier and the VX PL-PS Preamplifier.
The VX PP-KT88/C Push-Pull Stereo Power Amplifier and V SE-KT88/C
 are available now for suggested prices of $3,740 and $2,440, respectively. The other VEXO products are available for the following prices:They can be seen with other outstanding VEXO and Koetsu USA products at Suite 29-235 at the Venetian Hotel, during CES.
About VEXO Audio
VEXO Audio is a leading manufacturer of preamplifiers, amplifiers and integrated amplifiers. Based in Milan, the industrial and design capital of Italy, and owned by Carlo and Gianpaolo Contaldo, VEXO’s products reflect its painstaking and passionate approach to developing electronic components of uncompromising sonic performance and aesthetic design. True works of industrial art, VEXO products emerge in strict adherence to the company philosophy, “Performance and Design.” VEXO’s success is also based on its reliance on high-quality parts sourced entirely in Italy, and a decade of experience in the business. Its products deliver crystal clear fidelity, high dynamics, and rich micro-details on well defined-soundstages. For further technical information, visit www.vexohifi.it
About Koetsu USA
Koetsu USA is a vertically integrated distributor of high-end audio products including phono cartridges, tone arms, turntables, preamps, amplifiers, digital players, loudspeakers, cables, racks and other products. Its brands include Koetsu, Chario, Montegiro, Goldenote, Blacknote and VEXO. For further technical information, visit Koetsu USA’s Web site at www.koetsuusa.com.
