Home > Message Board > Press Releases > Archive through January 20, 2009 > JVC Develops 7mm Thin 32-inch LCD HDTV
Super Thin and Light at .28 inch (7mm) and 11lbs (5kg) Energy Efficient LCD Makes Possible Flexible Visual Environments
Victor Company of Japan, Limited (JVC) is pleased to announce that it has developed next-generation super-thin LCD technology for 32-inch television displays. The significant reduction in thickness and weight allow greater flexibility in the design and layout of commercial and household visual environments.
JVC
Primary Features of JVC's Next-Generation Super-Thin LCD Technology
  1. Integrating a new optical system and modular LCD construction, JVC technology has made possible the company's thinnest and lightest LCD television display at just .28 inch (7mm) in depth and 11lbs (5kg) in weight.
  2. The technology uses approximately 50% less material resources and approximately 10% fewer LCD module parts than current comparable JVC displays, while maintaining optical, intensity and low-heat radiation performance. Notably, use of LED as the light source eliminates the need for mercury.
  3. JVC developed new optical elements to realize this new LCD technology, overcoming technological restraints on thin displays to deliver an energy-efficient, high-resolution display exhibiting high contrast and luminance uniformity and a wide color palette.
Development Background
Consumer electronics makers wrestle with the challenge of developing thinner LCD displays in parallel with other advances, such as improving display resolution and reducing image lag. Thinner LCDs provide users with greater flexibility in the design and layout of commercial and household visual environments by overcoming restrictions imposed by the thickness and weight of existing products.
JVC
JVC achieved this goal by developing next-generation super-thin LCD technology that reduces thickness to .28 inch (7mm) and weight to 11lbs (5kg). This makes it possible to enhance visual environments in places where heavy displays are difficult to install, such as public spaces, amusement facilities, outlets, companies, schools and houses.
JVC's new technology also reduces the burden placed on the natural environment. The superthin LCD technology uses fewer material resources, features an energy-efficient proprietary driver system and eliminates the need for mercury, successfully balancing demand for thin, highdefinition LCDs with environmental responsibility. JVC will use this new technology to commercialize LCD solutions that enhance eco-friendly visual lifestyles.
