Home >
Message Board >
Press Releases >
Archive through January 20, 2009 >
HDMI v1.3 Splitter for Dual-Display Applications
| Posted by Linda Morgan on Monday, January 19, 2009 - 10:13 pm: |
The unit supplies one HDMI input that supports all versions of the HDMI interface. Two HDMI outputs connect direct to the two displays or projectors for a flawless delivery of high definition video with deep color and support for DTS Master Audio and Dolby TrueHD.
Resolutions up to 1080p full HD with HDCP compliance may be viewed on both displays simultaneously, and the Gefen splitter works with all of today’s Blu-ray players, gaming systems and set-top boxes using the HDMI format. For optimal performance, both displays should be set to the same high definition resolutions.
To distribute both audio and video to more than two displays, Gefen’s 1:2 Splitter for HDMI v1.3 can be cascaded to create larger distributions. Gefen also supplies a 1:3 Splitter for HDMI 1.3, a 1:5 HDMI 1.3 Splitter, and a 1:10 HDMI v1.3 Distribution Amplifier.
