Home > Message Board > Press Releases > Archive through February 02, 2009 > JL Audio W0v2 Car Subwoofer Drivers
High Performance and Affordable Cost
The term "overbuilt" gets thrown around a lot, but it really applies to the new JL Audio W0v2's. With beefy 2.0 or 2.5-inch voice coils and JL Audio's patented Elevated Frame Cooling for outstanding thermal power handling and stability, they can certainly handle power. Plus, their motors have been designed and refined using JL Audio's proprietary DMA modeling to reduce distortion, increase output and enhance overall fidelity. Best-in-class excursion capability results in increased output and better sound quality at higher listening levels, too.
An all-new stamped steel chassis underpins each W0v2 design and provides support for the flat, progressive roll spider, a very large positive roll surround and classy push terminals. The black mineral-filled polypropylene cone is finished with a concave dust cap, emblazoned with a white logo, in a manner that pays homage to JL Audio's classic woofer designs (including the original W0's). The motor structure is attractively finished with a molded cap that blends with the basket design. They definitely look like they mean business (and they back it up, too).
For maximum application flexibility, W0v2's are designed for use in compact sealed or medium-sized ported enclosures.
The W0v2 woofers' powerful combination of performance, value and installation attributes will make them the "go to" choice for those seeking high performance from an affordable subwoofer system.
W0v2
10W0v2
Nominal Diameter: 10 in. (250 mm)
Continuous Power Handling: 300 W
Xmax: 0.45 in. (11.4mm) one-way, linear
Impedence: 4 ohm (SVC)
Voice Coil Diameter: 2.0 in. (51 mm)
Rec. Enclosure: 0.65 cu.ft. / 18.4 liters (Sealed)
Mounting Depth: 4.90 in. (124 mm)
MSRP: $109.95/ea.
Availability: 1st Quarter, 2009
12W0v2
Nominal Diameter: 12 in. (300 mm)
Xmax: 0.45 in. (11.4 mm) one-way, linear
Impedance: 4 ohm (SVC)
Rec. Enclosure: 1,375 cu. ft. / 38.9 liters (Sealed)
Mounting Depth: 5.40 in. (137 mm)
MSRP: $129.95/ea.
15W0v2
Nominal Diameter: 15 in. (380 mm)
Continuous Power Handling: 500 W
Xmax: 0.50 in. (12.7 mm) one-way, linear
Impedence: 4 ohm
Voice Coil Diameter: 2.5 in. (64 mm)
Rec. Enclosure: 1.75 cu. ft. / 49.6 liters (Sealed)
Mounting Depth: 7.15 in. (182 mm)
MSRP: $229.95/ea.
Availability: 2nd Quarter, 2009
