Home >
Message Board >
Press Releases >
Archive through June 09, 2009 >
Crestron QM-RX1-2G QuickMedia Receiver
| Posted by Chris Benvenuto on Wednesday, June 03, 2009 - 04:45 pm: |
Delivers AV Signal Routing and Control in a New Low Profile, Compact Design
With built-in display control, audio DSP and stereo amplifier, the QM-RX1-2G provides complete connectivity for a display device, screen, lift, and speakers, and eliminates the need for outboard audio processing.
Perfect for installation behind a flat panel display or above a ceiling mounted projector, the QM-RX1-2G mounts simply onto a standard 2-gang US, UK, or European electrical box. Bidirectional RS-232 and IR/serial ports enable full control of the display device without additional wiring, and two relay ports are included on the QM-RX1-2G to control a projection screen or lift. Signal routing occurs automatically, based on the input source selected at the QM transmitter.
A digital input port can accommodate a room occupancy sensor or power sensor for enhanced automation and monitoring. Connections for the display device and speakers are all positioned on the top and bottom of the receiver, while the QM cable and screen/lift connectors are behind the unit within the electrical box. The QM-RX1-2G is available in black or white.
About Crestron
For nearly 40 years Crestron has been the world's leading manufacturer of advanced control and automation systems, innovating technology and reinventing the way people live and work. Offering integrated solutions to control audio, video, computer, IP and environmental systems, Crestron streamlines technology, improving the quality of life for people in corporate boardrooms, conference rooms, classrooms, auditoriums, and in their homes. Crestron's leadership stems from its dedicated people who are committed to providing the best products, programs and services in the industry.
In addition to its World Headquarters in Rockleigh, New Jersey, Crestron has sales and support offices throughout the U.S., Canada, Europe, Asia, Latin America and Australia.
