Home >
Message Board >
Press Releases >
Archive through June 26, 2009 >
Powersoft D-Cell504 Power Amplifier Module
| Posted by Debra Pagan on Monday, June 22, 2009 - 10:33 am: |
The stereo amp unit can deliver up to 350W @ 4 Ohm per channel in SE mode, or 700W @ 8 Ohm in bridged mode. The unit features six different types of protections, load monitoring for transducer diagnostics and an optional 2in/4out SigmaDSP processor (you need only one DSP to manage two amp units), easily programmable with Analog Devices’ SigmaStudio. A key feature of D-Cell504 is its versatility, thanks to the ability of the power supply to drive two amp units. This allows the user to easily power simple bi-amped systems, stereo or mono loudspeakers as well as complex multistage systems, subwoofer and satellites or three-way loudspeakers.
Offering an unprecedented degree of flexibility and ease of use, Powersoft is also releasing D-Cell in a completely new “integrated system” representing an incredibly compact and “ready-to-play” solution with up to four output channels in 100x330x110 mm of space. Up to three units (one power supply and two stereo amplifiers) can be hosted on a single chassis (only 100x330 mm in its default shape), performing thermal dissipation and including mains connection, an interface panel with XLR balanced stereo inputs or input plus direct output, LEDs for signal presence, input clipping, limiter and temperature protection, as well as preset selection pushbutton, preset selection LED, and connector to program the DSP with the module already mounted in the cabinet.
Power Factor Correction (PFC) built into the D-Cell504 provides consistent high-quality sound (the input voltage level is always controlled to give stable and optimal output performance), worldwide AC compatibility with operating range from 90 to 265 VAC and an overvoltage tolerance up to 400 VAC, and high reliability. With more than 90% of efficiency, PFC yields the benefit of superior performance with reduced energy for equivalent power output saving energy and reducing carbon footprint.
About Powersoft
Powersoft is the world leader in lightweight, high power, single rack space, energy efficient amplifiers for the professional audio market. Headquartered in Florence, Italy, with offices in Farmingdale, NY, Powersoft couples the experience and precision of its production department with exceptional components to deliver products with perfect audio response and high performance reliability. Its state-of-the-art amplifiers can be found in an array of markets, ranging from stadiums, sporting arenas, theme parks, performance venues and airports to convention centers, churches and clubs. For more information, visit the Powersoft Web site at www.powersoft-audio.com.
