Headphones
Sennheiser RS 160, 170, 180 Wireless Headphones
Photo: RS 160
The Sennheiser RS 160, RS 170 and RS 180 guarantee an excellent sound experience. Dynamic sound transducers with powerful neodymium magnets ensure a clear, high-resolution audio playback whilst the Kleer transmission technology promises uncompressed transmission of the audio data. The three new headphones will be shown for the first time at the IFA in Berlin.
“The RS 160, RS 170 and RS 180 headphones represent a perfectly free, wireless sound experience,” says Maurice Quarre, Head of Product Management Consumer Electronics at Sennheiser. “All three models offer highly impressive audio quality — with no cables to get in the way. They all use Kleer transmission technology, which operates without compression and therefore without any audio loss.” Not only can you move around while watching television but you can also enjoy cable- free music at a radius of up to 100 metres (RS 160 up to 20 metres, RS 170 up to 80 metres and RS 180 up to 100 metres, line of sight.
Sennheiser RS 170 Wireless Headphones Sennheiser RS 180 Wireless Headphones
RS 170 RS 180
Cinema-quality performance
The new RS models combine cinema- quality sound with movie star looks. “Clear lines and sophisticated, reflective surfaces in black, silver and anthracite make them genuinely desirable design objects,” continued Maurice Quarre. The headphones, with their soft padded ear cups and adjustable headbands, are specifically designed for hours of television or music enjoyment and are still comfortable to wear when your movie night eventually draws to a close.
Cinema-quality sound in the living room
Tried and tested Sennheiser technology ensures transparent and balanced sound with the new wireless headphones. Dynamic transducers with powerful neodymium magnets and a distortion of only 0.5 percent reproduce even the subtlest musical nuances. The frequency response reaches from 18 to 21.000 Hertz. With a sound pressure level of 110 decibels the three headphones have outstanding dynamics.
The RS 160 is the entry-level model: the closed headphones impress with their detailed sound and powerful bass reproduction. The volume can be controlled directly on the headphones. The RS 170 is also a closed model and delivers dynamic bass boost and switchable surround sound. The top-of-the-range RS 180 model is targeted at sound purists; the open design ensures a particularly natural listening experience which can be set to individual preferences. The speech intelligibility can be improved through dynamic compression (Automatic Level Control) and the balance can also be individually adjusted.
Plug and Play
It’s just so easy to connect the wireless headphones — whether to a television set, stereo system or DVD-Player. If the transmitter is connected to an audio or video device, it automatically transmits the audio data to the headphones: switch them on, put them on and sit back and enjoy the results. The 2-gigahertz digital radio transmission ensures smooth transmission with a high signal-to-noise ratio of 85 dBA. The Kleer technology even allows the listening pleasure to be shared as up to four headphones can receive radio signals via one transmitter.
The transmitter of the RS 160 has a diameter of only 9.7 centimetres. When connected to an MP3 player or mobile phone it fits easily into a backpack, which means that the headphones can be used for wireless music enjoyment whether you are at home or out and about. The RS 170 and RS 180 transmitters are a little larger as these also serve as a charging cradle.
All three models will be available worldwide from October.
High Tech Meets High Touch: Inside Sennheiser's High-End Headphone Factory in Tullamore, Ireland.
At $229, the Sennheiser ACCENTUM Plus wireless headphones add touch controls, Hybrid Adaptive Noise Cancellation, a travel case and more.
Sennheiser's new HD 490 Pro and HD 490 Pro Plus Studio Headphones made their debut at NAMM 2024 and are super impressive for $400....
At CES 2024, Sennheiser is introducing three new wireless noise cancelling headphones designed for fitness, travel, or audiophiles.
Start your year off right with the gifts that will bring you a higher fidelity entertainment experience in 2024.
Daily Deals
Sennheiser has extended some incredible discounts off their line of immersive soundbars, audiophile headphones, earphones and more.
Sennheiser's most affordable wireless noise cancelling headphones are tuned for younger music listeners who prefer pop and hip-hop.
Sennheiser has aggressively priced its new wireless active noise cancelling headphones to compete with models double its price.
