Home > Message Board > Press Releases > Archive through September 10, 2009 > NuVision Lucidium FX5LS Series Edge-lit LED HDTVs
NuVision U.S., Inc., manufacturer of high-performance 1080p Deep Black LCD displays, will display its all-new Lucidium FX5LS Series at CEDIA 2009 in Booth #2064. The Edge-lit LED units are super slim displays that require less power to operate, feature greener technology, truer color, deeper blacks, and sport parallel inputs designed for smoother installation. NuVision will be displaying its 40", 46" and 55" units.
"We really think installers and consumers alike will fall in love with our new line of E-LED's," said David Hester, Vice Chairman of NuVision. "Their slim frame and enhanced picture quality will make them a perfect fit into just about any room. Anyone that appreciates true high-quality electronics will find the FX5LS Series to be a true gem for their household."
All FX5 sets come with NuVision's own FX5 and FFM technologies. FX5 eliminates the need for the 3:2 pull down algorithm found in 60Hz displays, by recreating each frame five times, thus utilizing the 120Hz and high refresh rate of the panels. Many other LCD manufactures deploy black-frame insertion or simply attempt to double the frames in an attempt to achieve 120Hz. This works adequately when a motion sequence moves from left to right on the screen, but if it is reversed, the display reverts to its original 60Hz picture.
FFM is instrumental in creating clear, flicker-free fast sports and motion sequences by comparing two consecutive frames and generating additional interpolated frames. And for an additional benefit, NuVision makes it easy to shut both functions off completely to control any latency issues that may occur.
The new Lucidium FX5LS Series comes complete with a full, two-year manufacturer's warranty on all parts and labor.
About NuVision:
Founded in 2005, Scottsdale, AZ- based NuVision, Inc. is a manufacturer of high-end 1080p Deep Black LCD HDTV's. Known for their premium quality and elegant appearance, NuVision displays are truly made by connoisseurs, for connoisseurs. To ensure that customers receive the best support, service and set up, NuVision products are only sold through an exclusive, pre-qualified dealer network.
