Home > Message Board > Press Releases > Archive through September 17, 2009 > KeyScan KS810-Plus Imaging Keyboard / Scanner
KeyScan KS810-Plus Imaging Keyboard Scanner
KeyScan combines the power of a quick color scanner with keyboard for easy scanning of documents, photos, plastic cards, driver's licenses and more
KeyScan, the first exclusive inventor and developer of the integrated keyboard-scanner product and of the "NoTouch™-AutoScan" software, unveils the KS810-Plus Imaging Keyboard. This new and unique category of keyboard is a must have tool for any office or work area, the KS810-P delivers full A4 size page gray scanning in a quick 5 seconds making difficult scanning tasks easy. With 15 preset functions for non-default jobs, this imaging keyboard makes saving and emailing documents and photos effortless. The unique "NoTouch™-AutoScan" software allows the user to complete their most frequent scanning task without touching any button, simply place the document on the feeding tray. This new multi function peripheral (MFP) keyboard solution also features a USB2 Hub with only single USB connected to the PC both for the HUB the keyboard and the built-in scanner and two downstream ports for other low to high speed devices. KS810-P is available for $139.99 at TigerDirect.com, CompUSA and KeyScan.com
"Our new imaging keyboard puts the power of color scanning at your fingertips saving you space and changing your office into a paperless environmentally friendly workplace" says Dov Aharonson, CEO of KeyScan . "We are happy to provide a fast high quality imaging solution that will provide convenient emailing, archiving and copying solutions right from your keyboard."
The KS810-P is a fast USB2 sheet feed imaging keyboard that provides a multitude of features and scanning capabilities including:* Fax and copier functions require access to fax-modem and printer. May require 3rd party software.
About KeyScan:
KeyScan is an innovative developer of unique, highly efficient, personal interactive, productivity and communication scanning hardware and software tools. KeyScan provides the easiest way to capture documents, photographs and more directly to many Window applications, document imaging applications and to KeyScan Imaging Software. KeyScan is the original exclusive inventor and developer of the integrated keyboard-scanner product and of its distinctive software including the "NoTouch™-AutoScan" software.
