NAD C 245BEE Four-Channel Power Amplifier
Provides Numerous System Building Options, Power to Spare, Optional Bi-Amplification and Multizone Compatibility
NAD Electronics, the highly regarded manufacturer of high-performance audio/video components, introduces the C 245BEE Four-Channel Power Amplifier, an uncommonly talented installer-friendly amplifier.
The exceptionally versatile C 245BEE features a 4-channel architecture that provides installers with several system building options. When used with NAD’s C 165BEE Preamplifier, it delivers more than enough power to drive virtually any loudspeaker, as well as the option to bi-amplify. Connected to the Zone Output of an NAD AV Receiver, the C 245BEE can also send different music programs to remote speakers.
The C 245BEE was designed, like many earlier generations of award-winning NAD amplifiers, by NAD Engineer Emeritus, Bjorn Erik Edvardsen. Harnessing multiple discrete high-power output devices, it easily provides the instantaneous peak current required for good bass response.
The C 245BEE is rated at 35 Watts/per channel, Minimum Continuous Power, into 4 or 8 ohms, with all channels driven simultaneously, for 20Hz — 20kHz, with 0.03 percent THD (NAD Full Disclosure Power). It can also handle 55W, 85W and 100W Dynamic Power into 8, 4 and 2 ohms, respectively; and 2 x 90W Minimum Continuous Power into 8 Ohms in bridge mode.
Vanishingly low distortion and the near absence of noise allow music to emerge from a ‘black’ background that enhances stereo perspective, and enables the subtle details of the music to be clearly heard. Generous dynamic power gives music a relaxed yet lively quality. The power supply features a custom toroidal transformer that maintains very low impedance for the lowest noise possible and a good damping factor.
Value and Flexibility
The C 245BEE has three options for powering up: a front panel switch, a 12V trigger control (supported by many companion NAD products), and a signal-sensing ‘auto’ turn on. In Standby mode, it draws less than one Watt thanks to a separate high-efficiency power supply, saving power and reducing carbon emissions. A ‘vacation’ switch completely disconnects the power.
Each input has a ‘loop out’ feature allowing multiple C 245BEEs to share the same signal, which is ideal for elaborate custom installations. Pairs of channels can be switched on and off with Speaker A and B switches on the front panel. Additional refinements include a short signal path from input to output, gold-plated sockets, multi-way binding post speaker outputs, and a detachable IEC power cable.
Whether it’s used to bi-amp stereo speakers, add surround channels to a Home Theatre, or power music zones to a whole house audio system, the C 245BEE has what’s needed for great performance. Unique in its blend of performance and flexibility, the C 245BEE is also a tremendous value, equivalent to amplifiers costing two to three times more.
The C 245BEE 4-Channel Power Amplifier will be available later this month from authorized NAD dealers for a suggested price of $599 (U.S. MSRP).
Digital Music Systems
The last days of gear getishism? Network Amplifiers are the future of hi-fi, offering a one-box solution for audiophiles. Just add speakers.
Depending on your budget, the $499 NAD C 316BEE V2 might be the ideal stereo integrated amplifier to build a hi-fi system around.
Just what can one buy in 2024 for $4,500? The DALI Oberon 5 and NAD C 3050 make some serious music together on the...
NAD has 8 Vintage Listening Sessions scheduled across the U.S. and Canada in October and November. Find one near you.
Deal adds significant audio patents and codecs to Lenbrook's IP portfolio.
Canadian amplifiers from NAD and Bluesound win their respective categories at the 2023-2024 EISA Awards.
The Best CD Players for 2023 include some fantastic units from NAD, Naim, Rotel, Marantz, Audiolab, Cambridge Audio and more.
Looking for an affordable way to get into hi-res streaming this year? We have 10 digital streaming options from $219 to $2,200 that offer...
