Elite Home Theater Seating iPad Chair
Elite Home Theater Seating has introduced a new ergonomically designed chair specifically custom tailored for optimum iPad use. The “iPad Chair” features a whisper quiet reclining motor for the foot rest, lumbar support, elbow positioning, and a seat cushion normally found in a European sports car, all combine to help create the ultimate iPad experience.
With the Luxa2 H4 iPad holder firmly securing the remarkable device in its tight grasp with its 6 rubber pins, you can now wield the power of the iPad in total relaxation with both hands free. The holder slides into the existing cupholder of the Elite HTS chair, and can then swivel and pivot 360 degrees. In addition, the iPad can be rotated vertically or horizontally, and can even be positioned flat like a table. Like malleable modeling clay, a dynamic mechanical joint hinge holds any position, and delivers all the pivoting action.
In addition to sitting back and reading, the chair also becomes command central for providing complete home automation through the iPad. Companies such as Crestron and Home Logic now offer downloadable apps that transform the iPad into a beautiful, large home theater touch panel. With the Crestron Mobile Pro G app made specifically for the iPad, your personal fortress can be controlled by simply tapping the screen to select movies, view various security cameras, adjust light levels, room temperature, and volume with just a touch.
“The iPad is a user friendly, relaxing tool that allows you to complete tasks in a fun, efficient, and enjoyable way. The one drawback however, is that it can be a bit difficult to find the optimum ergonomic position when using it, especially since one hand is usually required to hold it. We wanted to enhance the iPad experience by increasing the comfort level of the user. Our testing indicates this increases the level of interaction and escapism with the device.”
— Bobby Bala, Founder and CEO, Elite Home Theater Seating
