JBL Cinema 500 Home Theater Speaker System
Harman announced the JBL Cinema 500, a 5.1 home theater speaker system with a dual-midrange center, four satellite speakers and a down-firing, 150-watt 8-inch (200mm) powered subwoofer.
The four identical satellites are voice-matched to the center for consistent sound from speaker to speaker, creating a more realistic 360-degree surround-sound field throughout the room. The Cinema 500 employ two PolyPlas cones in the center channel with a lower crossover point in the surrounding satellite speakers that have dual 3-inch (75mm) PolyPlas.
Cinema 500 System Technical Specifications
Frequency Response: 32Hz – 20kHz (-6dB)
Cinema 500 Satellite Speakers:
  • Low-Frequency Transducers: Dual 3″ (75mm) PolyPlas cones, video-shielded
  • High-Frequency Transducer: 1″ (25mm) titanium-laminate dome, video-shielded
  • Recommended Amplifier
  • Power Handling: 100 watts
  • Nominal Impedance: 8 ohms
  • Sensitivity (2.83V/1m): 89dB
  • Crossover Frequency: 3.7kHz
  • Enclosure Type: Sealed
  • Connector Type: Push-spring terminal
  • Dimensions — including stands: (H x W x D): 11-3/8″ x 4-3/4″ x 3-3/8″ (289mm x 121mm x 86mm)
Cinema 500 Center Speaker:
  • Recommended Power Handling: 100 watts
  • Dimensions — including stand: (H x W x D): 4-7/8″ x 12″ x 3-3/8″ (124mm x 305mm x 86mm)
Sub 140P Subwoofer:
  • Low-Frequency Transducers: 8″ down-firing cone
  • Enclosure Type: Ported (down-firing)
  • Amplifier Power: 150 watts
  • Frequency Response: 32Hz — 150Hz (–6dB)
  • Crossover Frequency: 50Hz — 200Hz (variable)
  • Controls: Volume, crossover frequency, phase
  • Connections: Left and right RCA line-level inputs, LFE input
  • Power Requirement: 120V/60Hz, 150W (US); 220V/60Hz, 150W (EU)
  • Power Consumption: <1W (8mA@120V) standby; 300W (2.5A@120V) peak
  • Dimensions (W x H x D): 19″ x 14″ x 14″ (475mm x 355mm x 355mm)
Pricing and Availability
The JBL Cinema 500 system is available for $699.
Every Super Bowl party needs a big screen with big sound. Enjoy the game with gift ideas to experience the full impact on any...
Earbuds & In-Ear Headphones
JBL's Live TWS 3 Series Earbuds feature a smart charging case that allows you to check messages and control smartphone functions whilst the phone...
JBL's SoundGear Sense and Tune 310C Earphones offer better sound quality, improved levels of comfort, and excellent value for the money.
Six new models featuring upgraded battery performance, support for Bluetooth 5.3, and Harman's advanced Personi-Fi 2.0 technology.
Add music to any party in 2024 with JBL's suitcase sized portable PartyBox speakers and optional wireless microphone.
JBL's rugged portable speaker line gets upgraded to Bluetooth 5.3 with LE audio and Auracast in 2024.
In this episode, Jim Garrett of Harman Luxury Audio reveals key details about Arcam's Radia series hi-fi components, JBL's MKII loudspeakers, and their acquisition...
Priced from $349, JBL extends its classic retro design into a new line of Authentics smart wireless speakers for the home.
