Home >
Message Board >
Press Releases >
Archive through 2008 >
Archive through August 16, 2004 >
Atlantic Technology’s Newest Ceiling Speakers are Ideal for Home Theater and ...
Atlantic Technology’s Newest Ceiling Speakers are Ideal for Home Theater and Distributed Audio
| Posted by Gordon Sell ... on Thursday, July 15, 2004 - 01:09 pm: |
The ICTS-8.2 and ICTS-6.2 each utilize a 1-inch silk dome tweeter mounted in a clever pivoting housing that allows installers and consumers to aim the high frequencies in any direction for the best sonic effect and the specific application. For instance, tweeter reproduction can be directed toward a primary listening position even when not mounted directly overhead, or reflected off a rear or side wall to provide the diffuse sound called for when the speakers are employed as the surround channels in a home theater system.
The ICTS –6.2 and ICTS–8.2 feature long-throw woofers which use Mica/Graphite-loaded polymer cones with rubber surrounds and high-temperature voice coils. The ICTS-6.2 uses a 6.5-inch woofer and has a frequency response of 55 Hz – 20 kHz (+/-3dB). Thanks to its larger 8-inch woofer, the ICTS-8.2's frequency range extends all the way down to 45 Hz.
The Atlantic Technology ICTS speakers utilize advanced computer-optimized crossovers, gold-plated heavy-duty connectors, and simple rotating clamp mounting for exceptional acoustic performance and easy installation. A front mounted three-position HF level adjustment that allows high frequency reproduction to be tailored to reflective, normal, or absorptive acoustic environments.
The ICTS 6.2 and ICTS-8.3 will be available in August at an estimated street price of $350/pair and $500/pair, respectively.
Atlantic Technology speaker systems are designed and engineered at the company's Norwood, MA facility as integrated multi-channel ensembles. These systems are tailored and tuned to provide a seamless and startlingly realistic soundstage for distributed whole-house audio, multi-channel music, and home theater.
For more information on Atlantic Technology and its many fine products for home theater and custom audio/video installation, visit www.atlantictechnology.com or call 781-762-6300.
