Thread: 04 hyundai accent head unit no rem wiring. need help! |
New member Username: Ohdeer
Post Number: 1 Registered: Aug-08
| Posted on Thursday, August 14, 2008 - 03:52 pm: |
ok so i recently purchased some very wimpy equipment, i bought two 6 inch subs and a 75 watt amp at a garage sale i have wired everthing on the amp and subs correctly, and have it connected to my battery. However i have the oem deck and it has no rca cable hookups or rem wire hookup. to remedy the rca cables i bought an adapter and soldered the wires fine however i need some advice on an alternate way to hook up my remote wire... |
Relevant Product Info
Post Number: 2 Registered: Aug-08
| Posted on Thursday, August 14, 2008 - 11:39 pm: |
i figured out that if i bought a switch and a fuse i could essentially take the control away from the head unit and do it my self. it works great however, i have a new problem now... when the car is off the system sounds great... however when i turn the car on it makes a sounds that sounds like a mix between a flatulent and a train stopping to the timing of my engine... anyone know anything? |
Bronze Member Username: Cd5honda96
OR
United States
Post Number: 80 Registered: Jun-08
| Posted on Friday, August 15, 2008 - 07:57 am: |
Alternator whining, try re grounding it to a different location if it still dose it ground your RCA's maybe just a suggestion. |
