Thread: 15" Alpine Type r amp?? |
New member Username: Hunter77
West milford,
Nj
United states
Post Number: 9 Registered: Sep-08
| Posted on Friday, September 26, 2008 - 05:13 pm: |
Hello i would like to know what would be a good amp for a 15 inch Alpine SWR-1542D??? I heard about the Hifonics Brutus 1608D and the ALPINE M850? Does anyone have any other suggestions? i really want this sub to slamm hard |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5507 Registered: Dec-05
| Posted on Sunday, September 28, 2008 - 12:43 pm: |
kicker zx 1000.1 |
Bronze Member Username: Heinzlmeir4
Post Number: 12 Registered: Oct-08
| Posted on Monday, October 20, 2008 - 08:37 pm: |
dudde the hifonics Brutus are overrated, they will only pump about 75-85% of what they say they are, the Alpine MRP-M850 is a soild amp but not enough to power your 15" Type R, get the MRP-M1000 that will power it nice or the kicker zx 1000.1, both those amps will push 1000Wrms @ 2 ohm |
New member Username: Ultimatebass
Blaine,
Mn
U.S.
Post Number: 8 Registered: Oct-08
| Posted on Wednesday, November 05, 2008 - 02:12 pm: |
^^x2. personally I like jl slash amps a 500/1 believe it or not will slam that sub with awesome sound. Trust me I have 2 R 15's on a 1000/1 and it kills . Price isn't bad either you can find the 500/1 for 300 shipped on ebay. Awesome price for a high quality amp. |
Gold Member Username: Drant19
DUB-C,
TX
Post Number: 1300 Registered: Aug-07
| Posted on Wednesday, November 05, 2008 - 03:26 pm: |
2 type-r 15s on a JL 1000/1??? they need more than that to really get moving. im sure you can put that amp on just 1 of those typeRs. Hunter, If you want that sub to slam then put 1000wrms on it at least. if its a dual4ohm sub then your amps are limited to something like a kicker zx1000.1 and that would be PERFECT. However, if you have the dual2ohm sub then you have lots of options for amps. remember that a better install makes for a better sound! INSTALL is KEY!!! lets start off with a few questions: 1. budget for amp? 2. do you have the wire kit already? |
Gold Member Username: 420alldaylong
Post Number: 3833 Registered: Sep-06
| Posted on Wednesday, November 05, 2008 - 11:16 pm: |
Phoenix Gold X600.1 Phoenix Gold RSd600.1 Kicker ZX750.1 |
Post Number: 16 Registered: Oct-08
| Posted on Wednesday, November 05, 2008 - 11:18 pm: |
gunnna neeed more than 600W rms or 750W rms to make that Type R hit hard, need like 1000W rms |
Post Number: 3834 Registered: Sep-06
| Posted on Thursday, November 06, 2008 - 12:55 am: |
Nope,there work just fine. |
Post Number: 3835 Registered: Sep-06
| Posted on Thursday, November 06, 2008 - 12:59 am: |
Remember build box to spec of sub. |
West milford,
Nj
United states
Post Number: 10 Registered: Sep-08
| Posted on Thursday, November 06, 2008 - 12:26 pm: |
my budget doesnt really matter i just want something that will slam it hard and be heard for miles. i want to get the most out of the sub. i am in the project of making a custom box its pretty sweet 3 cubic feet ported. i dont have anything currently but i will be getting it soon. i will be getting the 2 OHM version of the sub. |
Blaine,
Mn
U.S.
Post Number: 10 Registered: Oct-08
| Posted on Friday, November 07, 2008 - 05:07 am: |
Don't be fooled by the 1000/1's power rating. It makes those R 15's scream for mercy.... To me it sounds like 1600+ rms from comparable amps.. but that could be just me |
DUB-C,
TX
Post Number: 1303 Registered: Aug-07
| Posted on Friday, November 07, 2008 - 03:58 pm: |
"To me it sounds like 1600+ rms from comparable amps" what 1600+rms amps have you been listening to? "but that could be just me" ya thats just you man.. |
Bronze Member Username: Ultimatebass
Blaine,
Mn
U.S.
Post Number: 11 Registered: Oct-08
| Posted on Saturday, November 08, 2008 - 01:27 am: |
Haha well considering my last amp was a hifonics 1600rms compared to the 1000rms from the jl. The jl gave that a hifonics a run for its money buts its also more expensive too. I was thinking of selling that jl to get either an orion or a zapco wanna work the R's to the fullest |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1665 Registered: Mar-04
| Posted on Saturday, November 08, 2008 - 01:38 am: |
a ~$250 HF and a $700 JL are anything but "comparable". You have a notoriously over-rated 1600w amp, probably closer to 1200-1300 realistically, and an under-rated 1000w amp, probably around 1200 realistically. That explains why one "sounds like" the other. |
Bronze Member Username: Hunter77
West milford,
Nj
United states
Post Number: 11 Registered: Sep-08
| Posted on Tuesday, November 18, 2008 - 03:10 pm: |
how about any of these?? Power Acoustik A3000DB Power Acoustik ov14000d is the kicker zx1000.1 better???? i just wanna have a really powerful system im you ordinary teenager that wants to blow his ears out and set off car alarms and have the biggest, loudest sytem in school. |
Post Number: 19 Registered: Oct-08
| Posted on Tuesday, November 18, 2008 - 06:06 pm: |
are you getting the dual 4 ohm model or the dual 2 ohm cause if your getting the Kicker zx1000.1, your gunna want to get the dual four so you can run it at 2 ohm at 1000W. |
West milford,
Nj
United states
Post Number: 12 Registered: Sep-08
| Posted on Tuesday, November 18, 2008 - 08:57 pm: |
i can get whatever model i just want to make it pound. |
Post Number: 3873 Registered: Sep-06
| Posted on Tuesday, November 18, 2008 - 11:00 pm: |
Budget? |
West milford,
Nj
United states
Post Number: 13 Registered: Sep-08
| Posted on Wednesday, November 19, 2008 - 07:04 pm: |
i dont really have a budget |
Post Number: 20 Registered: Oct-08
| Posted on Thursday, November 20, 2008 - 07:06 pm: |
dudde cant go wrong with the dual 4ohm model and getting the zx1000.1 running it at 2ohm 1000W, if you build the proper box and to spec it will be real loud and pound |
Gold Member Username: Somedonniedude
Illinois
Braaap MX
Post Number: 2103 Registered: May-07
| Posted on Friday, November 21, 2008 - 10:16 am: |
JL slash amps are regulated, so if I'm correct they will do very near 1000w. no more and no less. |
Bronze Member Username: Lil_justin850
Justin smith, crestview,
Fl
Okalossa
Post Number: 30 Registered: Sep-08
| Posted on Friday, November 21, 2008 - 10:58 am: |
the kicker amp is for you i have owned one for over two years never gets hot hever has went in to protection mode and my birtsheet is rated at 1165 rms@ 2 ohms |
West milford,
Nj
United states
Post Number: 14 Registered: Sep-08
| Posted on Sunday, November 23, 2008 - 01:37 pm: |
thanks for all your help im gonna go out and buy the kicker  |
DUB-C,
TX
Post Number: 1331 Registered: Aug-07
| Posted on Sunday, November 23, 2008 - 03:47 pm: |
kicker zx1000.1 + 15" type-r DUAL4OHM! great set up |
