Home > Message Board > Car Audio > Amplifiers > Archive through October 23, 2008 > Amp keeps shutting off
Author Thread: Amp keeps shutting off
Username: Quinton_2872
I have one DVC 4 ohm sub running in parallel and one SVC 4 ohm sub that are running off of a 4 channel amp. I have both of them bridged so the DVC is a 2ohm load and the SVC is a 4 ohm load. I have the kicker KX800.4 amp and when I turn up the volume my amp cuts out and won't turn back on until i turn the volume down lower. How do I get this to stop?
Username: Adelphia83
Colorado Springs, CO
Post Number: 103
I don't think that amp is stable at less than 4 ohms bridged. When bridged it's rated at 400x2 @ 4 ohm mono. Each resulting channel (there are now two) should be a 4 ohm (or greater) load.
The SVC sub at 4 ohms is fine
The DVC on the other hand is 2 ohm, you're trying to bridge the amp at two ohms, something it's not rated for.
Try wiring the voice coils on the DVC in series. That'll probably make the problem go away.
Home > Message Board > Car Audio > Amplifiers > Archive through October 23, 2008 > Amp keeps shutting off [ « Previous ] [ Next » ]
