Thread: Question about running one dvc sub with two amps |
New member Username: Indyvdub
Indianapolis,
IN
Post Number: 1 Registered: Oct-08
| Posted on Monday, October 13, 2008 - 11:21 am: |
Hello, I'm trying to help a friend set up his system and he wants to power a dual voice coil sub with two amps (one amp hooked up to each voice coil). My question is whether or not this is recommended, and what do we need to pay attention to during setup (as far as things like matching gain settings, etc.)? Any help will be appreciated. Thanks |
Indianapolis,
IN
Post Number: 2 Registered: Oct-08
| Posted on Tuesday, October 14, 2008 - 12:20 pm: |
bump |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1627 Registered: Mar-04
| Posted on Tuesday, October 14, 2008 - 12:29 pm: |
If these are strappable mono amps it might be doable - depending on the impedance of the subs. If they're not strappable, but identical amps it could at least be an interesting experiment. If they're non-strappable amps and aren't identical it would be an experiment that might cost you an amp, or a sub, or both. |
Indianapolis,
IN
Post Number: 4 Registered: Oct-08
| Posted on Tuesday, October 14, 2008 - 01:58 pm: |
Thanks for the reply Optidriven. The sub would be an ID Max 12 with dual 2ohm voice coils. The amps would be Eclipse XA1000s, each putting out 400 watts @ 2ohms mono. I'm sure they're not strappable but could you clarify what that means? They would be identical but only as much as a mass produced amp can get if you know what I mean. |
Gold Member Username: •cam•
BC
Post Number: 2540 Registered: Nov-06
| Posted on Tuesday, October 14, 2008 - 06:14 pm: |
I've done it with a NINe.4 but it was slightly different. I bridged the rear channels, bridged the front channels, and matched the gains. Then checked again to make sure the gains were matched. It worked fine. I'm not sure I'd want to do it permanently though. Very slight differences in amplitude might be alright for a short time but after a while your sub might fall apart. I'm no expert but that's my guess. |
Lawrence,
Ks
Post Number: 1632 Registered: Mar-04
| Posted on Wednesday, October 15, 2008 - 05:25 pm: |
strapping is the same as bridging, but instead of bridging two channels you bridge two amps. It doesn't look like the xa1000 is specifically designed to be strapped, but I think you'd be ok running an amp on each coil as long as you follow Cam's suggestion and make sure each amp is set up as close to the same as possible. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5514 Registered: Dec-05
| Posted on Wednesday, October 15, 2008 - 06:08 pm: |
you SHOULD set your gain with a DMM |
