Home > Message Board > Car Audio > Amplifiers > Whats the best amp for 12'L7?durabili...
Author Thread: Whats the best amp for 12'L7?durability? quality?
Username: Trgft
I have 2 Kicker S12L7, what would be a good amp for them?
sonicelectronix gave me following:
1.Kole Audio KX1 3000D
2.Hifonics BXi 1608D
3.Power Acoustik LFA1 4000D
durability? quality? or if any other amps that you would recommend?
Username: Ctmike
Ct.
Post Number: 6629
budget and voice coils of the subs?
Username: Insearchofbass
Post Number: 10653
What year and type of vehicle? To see what kind of power you can support.
Username: Trgft
dual voice coils, (Kicker 08S12L74)
I a newbie, so I really dont have an idea on the amps. huge price difference really confused me. do I really get what I pay for? or just a brand name?
Thanks in advance.
Username: Trgft
2006 Range Rover Sport, will upgrade batteries or capacitors if needed
Username: Trgft
seems like none of these 3 listed are recommended. I have never heard these 3 brands,
some reviews show Hifonics has some poor quality products?
Username: N2audio
Lawrence, Ks
Post Number: 1638
the HF is decent, but a little over-rated. It claims 1600 but will probably give you 1300-1400.
The Kole claims 1700, but there's no way you'd get much more than 1000. The PA is rated 2200, you might get 1200-1500.
You're looking for about 1500w rms at 1 ohm which makes the HF a pretty good candidate, and fairly reliable. You might also check out the audioque aq1200d at audioque.com. I think it's still $250 shipped and will perform almost identically to the HF 1608.
The Powerbass ASA 1500.1D might be worth looking into. Also the Pioneer PRS-D1200M, slightly less power, but very high quality (physically small too).
Username: Nd4spd18
Philadelphia, PA
Post Number: 8598
Audioque 1200d would do ya perfect. Not a great choice of subs though, L7s are loud but they don't sound too good
Username: Trgft
Thanks for the reply guys.
let me put it this way, what kind of amp would you buy, if you have a pair of L7s?
M.S.: I do have heard what you've said over the internet, so what's a good sub for the same price range?
Username: Nd4spd18
Philadelphia, PA
Post Number: 8601
how much were you going to pay?
and that's a question you should post in the sub section for more answers.
Post Number: 10656
It looks like you might have a 100 amp alternator which means you will need an upgrade electrical wise if you do run 1200 watts. Dont buy a cap and skip the battery instead for an upgraded alternator.
Username: N2audio
Lawrence, Ks
Post Number: 1643
1200's doable on a stock charging system.
Barring extreme listening habits it shouldn't be much of a problem.
Username: Faroutdesign
St.ptersburg, Florida
Usa
Post Number: 21
anything 1 ohm stable with atleast a 100 amp fuse should be cool. im a kicker fan had 2 15" L7 08 15's i actaully had a 1500.1 which beat the hell out of them but i had it at 1.5 ohms dont ask how i got it there and why it worked i dont know either. accidently wire dual 4's in parallel then both in parallel but i had 10 gauge speaker wire which added some resistance i guess but it ran at 1.5 ohm stable all day. your either going to have a 1 or 4 ohm load the 1 ohm will be more efficient just find a mono block
Username: Nd4spd18
Philadelphia, PA
Post Number: 8747
cj you fail at car audio.... stop telling people to choose amps based on fuse rating
And yeah an AQ1200d shoold probably be ok an a stock electrical
Username: Bp_productions30
Post Number: 15
My, Opinion, I would say a kicker 1500.1, they are rated at 1500 watts peaks, but actually certified power rating will be alittle over 1500. I think it will be worth the money, plus kicker makes better amps and subs. Thier amps can run alittle high in price, but I thinks it worth it.
Post Number: 16
Username: Trgft
thanks for all the inputs guys. I did end up getting a kicker zx1500. they are actually 1625rms.
Usa
Post Number: 51
be very careful no bass boost and the gain should be up just about 1/4 way i almost cooked my 08 15" l7s with this amp and if you can get a hold of a signal driver your amp will run more efficiently to.
Username: 04redmach1
Es DEALER, GA
Post Number: 2420
If I'm not mistaken, the ZX1500.1 is 2 ohm stable and you have dual 4 ohm subs. I think you made a boo boo.
Kevin
Usa
Post Number: 53
he should be fine. i ran mine at 1 ohm accidently but i had 10 gauge speaker wire so it added about half ohm resistance and the amp never clipped once
Post Number: 17
Correct me if I am wrong, but I thought if you are running kicker L712D4's, in parallel to a kicker 1500.1 it draws a two ohm load. I could be mistaken though.
Username: Somedonniedude
Illinois
United States
Post Number: 2056
"he should be fine. i ran mine at 1 ohm accidently but i had 10 gauge speaker wire so it added about half ohm resistance and the amp never clipped once"
That makes no sense^^^^ Don't listen to him.
If it's not too late, cancel that order or return the amp. It's going to cost alot of $$$ to properly run that amp in your situation. H3ll my car couldn't handle my zx750.1 @ 1 ohm, but it handles my AQ1200D awesome! I don't think adding a battery will help you much in this case, you might need a HO alternator as well.
Usa
Post Number: 55
well bro aparently no one here knows how to add or calculate ohms law. so learn something. if he is running a total of 4 4 ohm coils he will have a load of 1 ohm how ever wire lenght wire quality/gauge and terminal connections can add resistance as in my case it did equaling a 1.5 ohm load. i ran my zx1500.1 on a 1.5 ohm load no problem and it was maxing out my 15's so unless you ve run this set up dont post.
Illinois
United States
Post Number: 2057
"well bro aparently no one here knows how to add or calculate ohms law. so learn something. if he is running a total of 4 4 ohm coils he will have a load of 1 ohm how ever wire lenght wire quality/gauge and terminal connections can add resistance as in my case it did equaling a 1.5 ohm load. i ran my zx1500.1 on a 1.5 ohm load no problem and it was maxing out my 15's so unless you ve run this set up dont post."
I'm not challenging Ohms Law, I'm saying that if your speaker wire and terminals added 0.5 ohms, then your install was sh!t. Do you think his electrical will handle 1500+w anyways? Probably not. And please stop recommending where people should set their gain controls at, but I'm sure you have the same HU/EQ as him too huh?
Username: Trgft
Post Number: 7
sorry, I forgot to update the info, I got the 2ohm L7 instead of the 4ohm.
my setup is:
two08s12L72andzx1500.1
mine amp set at 0 bass boost and 1/4gain. 50hz cross-over
Usa
Post Number: 57
well then your fine man series the coils and parallel the subs thats a 2 ohm load. oh and raise your crossover to about 80. twelves are able to take those frequencies
Username: 420alldaylong
Post Number: 3827
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=22
I would atleast upgrade stock wiring to bigger gauge.(0gauge)
Username: Trgft
Post Number: 8
any recommendation? with a link would be helpful. thanks
Username: Nd4spd18
Philadelphia, PA
Post Number: 8817
" I'm saying that if your speaker wire and terminals added 0.5 ohms, then your install was sh!t. "
X2
If your wire terminals add any measurable amount of resistence your install is sh!t
Username: Trgft
Post Number: 9
well, I got the L7s in a pre-wired kicker box with only one positive and one negative on the box. I just hooked them onto the amp.
Usa
Post Number: 66
well i dont use speaker terminals i use bolts. and not ever sub is the xact impedance as stated on the box it can be off by a half or less. and the impedance changes as the speaker moves in and out. so yes its possible to have achieved 1.5 ohm with my install and i dont do garbage
Username: Bldgjf
Welcome to our website (www.mallcc.com)
Username: Bldgjf
Welcome to our website (www.mallcc.com). we (Mallcc Export Trade Co.,Ltd.)supply many products, such as shoes, hoodies, jeans, coats, shirts, jerseys, sweaters, sunglasses, belts, watches and hats . We also provide handbags, purses, electronic products, jewelry, shawls, travelling bags, underwear, neckties and lady suits. You can have a wider selection of styles and brands from our website. Moreover, we supply all products with wholesale prices.We accept big or small quantity order and mixed order.
If you are interested in our commodities, welcome to our website and contact with us.
Website: www.mallcc.com
E-mail: mallcc@live.cn
We have an ample supply, so we can delivery the commodities immediately once we got your confirmation. Your choice is classic! Hope to make a long term business relationship with you. Any inquiry is welcomed.
Username: Boston_spl
Highland, CA
United States
Post Number: 20
WTF?
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Amplifiers > Whats the best amp for 12'L7?durabili... [ « Previous ] [ Next » ]
