Home > Message Board > Car Audio > Amplifiers > Archive through October 23, 2008 > Phase 2
Author Thread: Phase 2
Username: Gnarkiller
Selah, Wa
Usa
Post Number: 11
Ok the mono amp for my subs should arrive any day now and I will almost be ready to get my car sounding twice as good.
So now that Im using a new amp for my subs. the next question is how should i set up my type R components?
So I was thinking I should use my power acoustik amp that puts out 150 rms x2 at a 4 ohm load. With my type R's being rated at 110 per set, could I just set it up with the gain lowered watching out for stess, or distortion on my speakers??? I was reading one of glasswolf's posts about zero reference tone but i got confused. and it seems like the power acoustik is made mainly for subs. will this be bad for sq? Keep in mind I have sony 4 channel amp that is a POS and I got for free. I think puts out around 130 bridged. *Also I was reading a deal on crutchfield that says you get what you pay for on an amp and cheaper amps ruin imaging etc.
Also what wiring package should I get? do i need to get an extra fuse by the battery?
I will post additional info about the amp models and stuff it needed.
thanks
Username: Nd4spd18
Philadelphia, PA
Post Number: 8639
the pa amp should be fine for the speakers.
Look up what gauge power wire the amps need get a kit with that gauge.
And yes anytime you have a power wire connect to the battery it must have a fuse there no exceptions.
Home > Message Board > Car Audio > Amplifiers > Archive through October 23, 2008 > Phase 2 [ « Previous ] [ Next » ]
