Home > Message Board > Car Audio > Amplifiers > Audioque 2200D
Author Thread: Audioque 2200D
Username: Andrew16639
Miramar, FL
United States
Post Number: 33
How do you get the amp to push past 2200watts.
Specifications
Model AQ2200D
Digital Monoblock 1 ohm stable
Input Sensitivity 0.2v-8v
Variable Low Pass Filter 20Hz-200Hz @ 24dB/Oct
Subsonic Filter 10Hz-50Hz @ 24dB/Oct
Output Master / Input Slave, 2 amps linkable connection
Remote Level Control
Clipping Display Led
Signal to Noise Ratio 90dB
External Fuse Rating 200 Amps, 400 Amps Linked
Tested Voltage and THD 14.4V & 1% THD
4 ohm power 740 x 1
2 ohm power 1300 x 1
1 ohm power 2200 x 1
1 ohm Power @ 16V @ 1% THD 2500 x 1
1 ohm Power @ 16V @ 10% THD 3400 x 1
2 ohm Linked Power @ 14.4V @ 1% THD 4400 x 1
Dimensions 17.71"(L)x9.27"(W)x2.35"(H)
http://www.audioque.com/aq/AQamps2200D.htm
Relevant Product Info
Username: Bonhamd
Post Number: 1309
it is rated at 2200 RMS
the only way you could get more power out of the amp is to drop it to a lower ohm load
this is only safe if you know what you are doing and have a good electrical system to back it up
Username: Nd4spd18
Philadelphia, PA
Post Number: 8646
Stop asking stupid questions...... the amps rated 2200w, its not gonna do more than that. duh
Username: Van_man
Boston South, MA
Post Number: 4390
run it at 16 volts at 1/4 ohm.
Username: Nd4spd18
Philadelphia, PA
Post Number: 8651
hahaha
Miramar, FL
United States
Post Number: 34
what is THD and how do you raise it. also how do you get or run 16 volts
Username: N2audio
Lawrence, Ks
Post Number: 1647
you want to raise THD huh??
GENIUS!
You run 16 volts by building a secondary electrical system for your car which is installed in addition to the standard 14v system.
FWIW (I'm guessing very little) with a 2200w amp it would take an additional 1000w or so, and a speaker that could make use of it, to produce a noticable improvement in output.
Username: Nd4spd18
Philadelphia, PA
Post Number: 8654
haha this guy is a real genius.
First of all that amp won't run at 1/4 ohm.
Second lower THD is better not higher lol.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 5521
i think a 2.2K rms system is plenty loud for you and all of us, so stop sking stupid ways to blow your sh1t up
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Amplifiers > Audioque 2200D [ « Previous ] [ Next » ]
