Home > Message Board > Car Audio > Amplifiers > Cadence TXA-3002
Author Thread: Cadence TXA-3002
Username: R_davis
Brookneal, Virginia
Post Number: 21
I've got two Alpine swr1242's,What's the most power I can get to these from Cadence TXA-3002 amp? specs. 300rms x 2 at 2ohms, 600rms x 1 bridged 4ohm.
Relevant Product Info
Username: Nd4spd18
Philadelphia, PA
Post Number: 8652
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qt y=2&woofer_imp=4
option 2
bridge the amp
Username: R_davis
Brookneal, Virginia
Post Number: 22
Can it be bridged to 2 speakers at 2ohm? If so what rms watt?
Username: Nd4spd18
Philadelphia, PA
Post Number: 8680
Wire them like that, this ain't hard..... look on the amp or in the manual to find out which + and - terminals you need to use to run it bridged.
And no those subs can't be wired to 2 ohm, nor can your amp handle that.... wire it like I said and you will get 600w, 300w per sub, thats the most you can get from that amp.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Amplifiers > Cadence TXA-3002 [ « Previous ] [ Next » ]
