Home > Message Board > Car Audio > Amplifiers > 2 battery's + amp wiring
Author Thread: 2 battery's + amp wiring
Username: Jahsonas
Hi,guys,do i need additional fuse from back battery to the amp? i have 100a fuse installed in the front,thanks
Username: Bonhamd
Post Number: 1355
yessir you sure do
Username: Somedonniedude
Illinois
United States
Post Number: 2041
You should fuse before and after the rear battery, and make sure to keep the fuses as close as you can to the battery (within reason).
Username: Nd4spd18
Philadelphia, PA
Post Number: 8741
Anywhere you have a positive wire connecting to a battery you need a fuse rated for that wire.
Username: Hittin1
Lake Charles, La.
United States
Post Number: 1563
http://www.bcae1.com/fuses.htm
Username: Hittin1
Lake Charles, La.
United States
Post Number: 1564
read more than once^^^^
A pic is worth
1000 posts!!
Post Number: 18857
Don't forget about...
http://www.the12volt.com/
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Amplifiers > 2 battery's + amp wiring [ « Previous ] [ Next » ]
