Thread: Bridging Question |
New member Username: Yenkozl1
PHOENIX,
AZ
UNITED STATES
Post Number: 2 Registered: Oct-08
| Posted on Wednesday, October 29, 2008 - 01:32 am: |
I am going to run 2 JL 10W3V3 4ohm subs to one JL 500/1 amp. I know by doing this the ohms reduce to 2. Will this cause the amp to work harder than normal? Do you think the amp might get too hot? I hear a lot of good and bad things about bridging. Looking for opinions on whether I should run single or multi amp setup. |
Relevant Product Info
Gold Member Username: Nd4spd18
Philadelphia,
PA
Post Number: 8759 Registered: Jul-06
| Posted on Wednesday, October 29, 2008 - 02:54 am: |
Umm, a JL 500/1 is a mono amp, you can't bridge it.... bridging is when you run a 2 channel in mono making it act like a 1 channel. That amp can handle any impedance 1.5-4 ohms just fine. It will have no problem with your W3s. |
PHOENIX,
AZ
UNITED STATES
Post Number: 3 Registered: Oct-08
| Posted on Wednesday, October 29, 2008 - 02:11 pm: |
Oh, ok. So bridging is only for mutli cahnnel amps. Got it, thanx for the help M.S. So, I will still be at 4ohms with this setup. Nothing will change. That's great. Once again thanks. |
Philadelphia,
PA
Post Number: 8769 Registered: Jul-06
| Posted on Wednesday, October 29, 2008 - 02:50 pm: |
If you have two 4 ohm speakers you need to wire them in parallel, which makes a 2 ohm final load. Which is fine for that amp. Slash series amps are regulated, the impedance makes no difference as long as its within the 1.5-4 ohm range. |
