Home > Message Board > Car Audio > Amplifiers > New System, What Do You Think
Author Thread: New System, What Do You Think
Username: Perezreyesm
Woodbridge, VA
Usa
I am building my first system my car. I have done lots of research and have come up with this.
Its a 2003 dodge neon.
My budget is about $1000 (+-$100)
I listen mainly listen to hip-hop, rap, techno (trance).
Then some classic rock, some metal, and some alternative
I am looking for great SQ let me repeat that SQ is the top priority in this build, but I still would like to be able to turn up the bass to loud levels and impress people
I want something that will give adjustability especially the bass. Will an amp with a remote give me this adjustability?
This is my list so far but I am willing to completely change it based on your suggestions.
Head Unit-http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19512
Font speakers-http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17563
Rear speakers-http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17564
Amp for interior speakers-http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19584
Subwoofers:
I am thinking a sealed box (for better SQ) probably pre-made as I currently don't have the tools to make one but I may try to build one if you advise its the best choice.
Probably this one-http://www.sonicelectronix.com/item_7604_Sonic+Sub+Box-+2H12-1.5.html
I was originally thinking two of these-http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17651
or these-http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16898
but I got scared because they don't seem too popular and I am not too sure on SQ or general quality
now I am looking at two of these-http://www.sonicelectronix.com/item_4281_Alpine+SWR-1242D+-TYPE+R-.html
how good is the SQ on these subs?
I am also think two twelves might just be too much bass and I wont be able to hear the music.
would two tens be better in terms of SQ and SPL as far as bang for the buck
I kind like the idea of just one really good 12" I think that would be a little cheaper what would you suggest?
heres the amp I was planning to use wit the type Rs-http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19580
I know Hifonics isnt the best but i have read that they are good bang for the buck
Finally what wires to use? are some brands better than others
I have been looking at -http://www.knukonceptz.com/productMaster.cfm?Category=RCA%20Interconnects
but their stuff is really expensive any ideas?
I know this is a long post but I tried to be specific thanks in advanced for any help.
P.S. Is it okay to post this in other sections?
Username: Nd4spd18
Philadelphia, PA
Post Number: 8788
Most of that is decent equipment with a few exceptions:
Kenwood subs are junk, type Rs are pretty good so no contest there.
Really bad choice of amps. Hifonics Zxi series are complete junk and the Bxi are only slightly better... and all are overrated. It sounds like you're wanting stuff readily available on the retail market so I would recommend you look at Alpine amplifiers. And headunits for that matter, they're top of the line there, although the Kenwood is ok.
For wire the best bets will probably be kicker amp kits on ebay or wire from www.knukonceptz.com
Username: Faroutdesign
St.ptersburg, Florida
Usa
Post Number: 45
i think the alpines are good but i might try a type x ive had alot of issues with cone seperation with the ribbon surrounds. and hifonics amps are cool and all but like m.s said they arent the best. i really think you could do better with a highs amp something with better features alpine does make really good highs amps. but try and get dual 4 ohm subs so you can run a mono block how ever i did install an alpine amp dont remember which model but it worked them lovely so you may be good with running all alpine.even an alpine head unit especially one with a 7 band eq and up. im not to sure but i think thier amps and head units link some how but then again im not sure
Username: Insearchofbass
Post Number: 10731
id suggest an eclipse 7200 mkII it has 8 volt preouts time alignment etc. $388 shipped.
http://cgi.ebay.com/NEW-2008-ECLIPSE-CD7200mkII-8-VOLT-CD-MP3-USB-BLUETOOTH_W0QQ itemZ360103031539QQcmdZViewItem?hash=item360103031539&_trkparms=39%3A1|66%3A2|65%3A15|240%3A1318&_trksid=p3286.c0.m14
and a stereo integrity mag 12 249.00 shipped
http://stereointegrity.com/order.php
and a Audison LRx1.400 900 watts at 1 ohm
364.94 shipped
All of that would make for a good sq system at $1001.94.
Username: Treez
Its not loud til it he...
Post Number: 408
"I am looking for great SQ let me repeat that SQ is the top priority in this build, but I still would like to be able to turn up the bass to loud levels and impress people"
I didnt read anything past that sentence and i'll recommend the following for subs;
Idmax v.3
soundsplinter rl-s
Boston Acoustics g5
jl audio w6v2
Treo SSI
Woodbridge, VA
Usa
I understand that a good sub is important but the things yo guys are suggesting take up most of my budget I still want to upgrade the mids and high what do you guys recommend
Usa
Post Number: 56
get some of the pioneer premier 3000 watt subs about 200 for the pair plus shipping i love them they may not be super amazing but they are clear and they can boom. i did a ford focus with a pair and i had "plies" compliment the system
Username: Nd4spd18
Philadelphia, PA
Post Number: 8805
Pioneer doesn't have sh!t on the subs treez listed.....
And yes the component speakers will be the most important upgrade
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Amplifiers > New System, What Do You Think [ « Previous ] [ Next » ]
