Thread: Help me... I don't have a clue |
New member Username: Payneintheneck
Post Number: 1 Registered: Oct-08
| Posted on Saturday, November 01, 2008 - 04:09 am: |
okay so a little bit of background first... i know absolutely nothing about car audio... subs, amps, ohms, watts, mono, stereo... that is all a foreign language to me... so i need some help... I am looking to buy an amp for my new sub... I just purchased a Kicker CVX15... and i want an amp that will give me the best performance possible out of my sub... what amps to you recommend? mono or stereo? i dont know... please help me... thank you!! |
Gold Member Username: Nd4spd18
Philadelphia,
PA
Post Number: 8789 Registered: Jul-06
| Posted on Saturday, November 01, 2008 - 02:42 pm: |
For a sub you need a mono class D amp. Now in order to know if you need a 1 ohm or 2 ohm stable amp we need to know what coils your sub has. If it's dual 4 ohm, Kicker ZX750.1 or ZX1000.1 If it's dual 2 ohm, Audioque 1200d There are certinaly other good amps but IMO those are the best value and still are good quality. |
Post Number: 2 Registered: Oct-08
| Posted on Monday, November 03, 2008 - 01:12 am: |
my sub is a dual 4 ohm, so probably the ZX1000.1? |
Philadelphia,
PA
Post Number: 8804 Registered: Jul-06
| Posted on Monday, November 03, 2008 - 10:20 am: |
That would be my choice |
Gold Member Username: Hittin1
Lake Charles,
La.
United States
Post Number: 1562 Registered: May-07
| Posted on Sunday, November 09, 2008 - 07:14 pm: |
That amp is made for that sub.. perfect match. |
Platinum Member Username: Wingmanalive
A pic is worth
1000 posts!!
Post Number: 18856 Registered: Jun-06
| Posted on Sunday, November 09, 2008 - 10:27 pm: |
"okay so a little bit of background first... i know absolutely nothing about car audio... subs, amps, ohms, watts, mono, stereo... that is all a foreign language to me... so i need some help... I am looking to buy an amp for my new sub... I just purchased a Kicker CVX15..." Isn't that putting the cart in front of the horse a bit? If you know nothing about anything why buy a sub blind then ask to have an amp paired with it? I'm not hatin' on your choice of sub BTW. |
Platinum Member Username: Rovin
1 15 = 149.5 DBs Trinidad & T...
Post Number: 14365 Registered: Jul-05
| Posted on Wednesday, November 12, 2008 - 06:28 pm: |
^paully got a good point there ... but that ZX1000.1 is a good match ... |
