Home > Message Board > Car Audio > Amplifiers > Planet Audio Big Bangs 2 dual voice c...
Author Thread: Planet Audio Big Bangs 2 dual voice coil 2ohms
Username: Mbyte
Hudson
U.S.A
I have 2 dual 2ohm DVC subs and a 2-channel amp. I was wondering if anybody could tell me how to wire them to get 1 ohm if it is possible}
Username: Southernrebel
Monroe, Louisiana
Team Audible...
Post Number: 6973
No...you can not get a 1ohm load from both your subs.
You can get 1ohm from ONE of your subs though.
If you run both subs, you can get 8ohm, 2ohm, or 1/2ohm.
If you plan to run both subs, look for a 2ohm stable amp that will give you the power you need.
Username: 04redmach1
Es DEALER, GA
Post Number: 2421
What kind of budget do you have for amp? May can do 2 1000.1's and strap them at 2 ohms :-)
Kevin
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Amplifiers > Planet Audio Big Bangs 2 dual voice c... [ « Previous ] [ Next » ]
