Thread: A pair of Pioneer Premier TS-W3001D4 12" with what amp? |
New member Username: Markymark88
Oakland Township,
MI
Post Number: 1 Registered: Nov-08
| Posted on Wednesday, November 05, 2008 - 07:47 pm: |
I am going to get a pair of Pioneer Premier TS-W3001D4 12" to put into my 2000 Chevy Blazer. They have a peak of 3000 watts and i think like 1000 RMS. What amp would be best for this? and also thinkin of a new reciever? try to keep it within $700. Thanks |
Gold Member Username: 420alldaylong
Post Number: 3836 Registered: Sep-06
| Posted on Thursday, November 06, 2008 - 01:05 am: |
http://www.audioque.com/aq/AQamps2200D.htm http://www.sonicelectronix.com/item_5378_JVC+Arsenal+KD-AR8500.html?name=JVC+Ars enal+KD-AR8500&sonic_special=2 |
Oakland Township,
MI
Post Number: 2 Registered: Nov-08
| Posted on Thursday, November 06, 2008 - 03:37 pm: |
Thanks dude but i think I may hav found a good amp. Made by Boss with a max of 4000v. Wouldu recommend any Capacitor? and if so what farad? |
Gold Member Username: Nd4spd18
Philadelphia,
PA
Post Number: 8847 Registered: Jul-06
| Posted on Thursday, November 06, 2008 - 04:57 pm: |
That is NOT a good amp if it's made by boss. Don't try to cheap out with amps, you get what you pay for. Capacitors will not do anything, unnessecary. That AQ 2200 is a great value, hard to find a good quality amp for less.
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1661 Registered: Mar-04
| Posted on Thursday, November 06, 2008 - 10:48 pm: |
Which boss? Best case scenario a 4000w boss is going to give you 2000 usable watts, poor efficiency, and iffy reliability. The audioque will give you 2200-2400 usable watts efficiently and reliably. |
Gold Member Username: Drant19
DUB-C,
TX
Post Number: 1306 Registered: Aug-07
| Posted on Saturday, November 08, 2008 - 07:50 pm: |
^^^well put. and just throwing this out there cuz your still talking about "peak watts", do you have any electrical upgrades? you'll need them to run 2000rms |
Platinum Member Username: Rovin
1 15 = 149.5 DBs Trinidad & T...
Post Number: 14364 Registered: Jul-05
| Posted on Wednesday, November 12, 2008 - 06:26 pm: |
honestly i would rec different subs since better can be had for around the same price anything from RD audio sundown audio RE audio audioque etc ... |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 5524 Registered: Dec-05
| Posted on Wednesday, November 19, 2008 - 08:28 pm: |
rovin had them for a while so he knows what he's saying |
