Home > Message Board > Car Audio > Amplifiers > Wire a dual 4 ohm subwoofer to 1 ohm?
Author Thread: Wire a dual 4 ohm subwoofer to 1 ohm?
Username: Tom14pep
I have a Rockford Fosgate amp that puts out 1295rms at 1 ohm. I am looking at puchasing an Alpine type x 12" suboofer that is dual voice coil 4ohms each coil. Is there any way possible to get this to wire down to 1 ohm? because the amp only puts out 750rms at two ohms. I would love to use the full capacity of my amplifier in order to make the sound as loud as possible. I have looked and i can't seem to find an Alpine type x 12" in a dual voice coil that has 2 ohms each. what should i do? is it possible? Is there any subwoofer that would be able to use the full capacity of my amp?
Username: N2audio
Lawrence, Ks
Post Number: 1659
check out the BL12 from ficaraudio.com.
I don't have personal experience, but Fi seems to be one of the hotter subs going right now.
Username: Bonhamd
Post Number: 1413
no you cannot wire a single type x dual 4 down to 1 ohm
you could wire it to 2 ohms or 8 ohms
you would need a dual 2 ohm subwoofer if you are going with a single sub setup
What is your budget and are you looking for SPL, SQL, or SQ?
SPL - Loud
SQ - Sound Quality
SQL - A mixture of both
Username: Tom14pep
Post Number: 7
I am looking for a good combination of both for around 250
Username: Bonhamd
Post Number: 1415
what kind of car do you have?
Username: Tom14pep
Post Number: 8
97 Monte Carlo
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Amplifiers > Wire a dual 4 ohm subwoofer to 1 ohm? [ « Previous ] [ Next » ]
