Home > Message Board > Car Audio > Amplifiers > 750-1000wrms amp?
Author Thread: 750-1000wrms amp?
Username: Vivi2000
Post Number: 66
Im going to be purchasing a single 15" type R and was wondering what amp i should get with it. I was looking at the kicker 750.1 and the hifonics bxi1200d. Budget is about $250 shipped for the amp. I have a 105A alternator and am going to do the big 3 when I get my new wiring. Any suggestions?
Username: Nd4spd18
Philadelphia, PA
Post Number: 8848
Audioque 1200d
Always good to have more power than you need.
Since thats a 1 ohm amp make sure you get a dual 2 ohm sub.
Username: Vivi2000
Post Number: 67
ok, i just didnt know if that sub could take that much, which is why i was looking at the kicker and the hifonics. Now will my alternator be able to power that without an extra battery?
Username: Nd4spd18
Philadelphia, PA
Post Number: 8863
You don't have to give the sub the amps max output, I'll say it again
The kicker is the wrong impedance that will not work. The hifonics is a low quality amp.
There is now real way to know what the electrical system will support until you try it.
Username: N2audio
Lawrence, Ks
Post Number: 1660
The 1542 and the zx750.1 would make a great combo IMO.
Username: Vivi2000
Post Number: 68
My friend has that same hifonics amp, seemed good(besides being overrated). I think ill just go with the kicker amp then.
Username: Nd4spd18
Philadelphia, PA
Post Number: 8866
The kicker is a good amp but to run that you have to get the dual 4 ohm version of the sub
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Amplifiers > 750-1000wrms amp? [ « Previous ] [ Next » ]
