Home > Message Board > Car Audio > Amplifiers > ARC or PPI
Author Thread: ARC or PPI
Username: Treez
Its not loud til it he...
Post Number: 409
So i've decided on going old school.
I narrowed it down to those two brands.
My aim is sql.
I'm comparing the xxk/cxl series with the art/pc series.
The s/n ratios are similar and amps are all underrated.
Can anyone offer advice as to the which amp would be the most transparent, efficient and reliable? Or simply put, the cleanest of them all.
Thanks
Username: Drant19
DUB-C, TX
Post Number: 1307
cant ever go wrong with ppi art series amps.. jake papa used them, iirc
Username: Treez
Post Number: 410
i've heard nothing but great reviews on every single brand and series i've mention above.
The slight advantage of the arc's and the pc series over the art series is the onboard crossovers.
Also, the Damping factor on the arc's are ridiculously high. lol
This makes for a very tough decision.
Thanks for the input
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Amplifiers > ARC or PPI [ « Previous ] [ Next » ]
