Home > Message Board > Car Audio > Subwoofers > Archive through December 05, 2008 > L7s or Type Rs?
Author Thread: L7s or Type Rs?
Username: Jake112990
I am looking to buy new subs since my L5s just blew. I was looking at either getting L7s or Type Rs. I have a JBL BP1200.1 amp. Here is the specs for the amp - http://www2.dealtime.com/xPF-JBL-BP1200-1. I want the subs to be really loud but have sound quality too. If anyone has any suggestions please share.
Thanks!
Username: Surferdude9371
Get loud or go home....
Post Number: 1411
between the two type rs are the only that will have any sq whats your budget are you open to suggestions?
i dont really want to spend over $400 so ill prob get them off ebay. but i open to any suggestions
Username: Ducka
Houghton and/or Macomb, MI
United States
Post Number: 692
What size... There is not much of a price difference between the 15s, but there is almost a 100 dollar difference between the 12s. I haven't heard a L7, but the type-rs are great.
Post Number: 1412
l7 is loud but has no sq what are the stats of that amp im sure we can get you a great single sub set up for 400
Username: Shade
Moxee, Wa
U.S.
Post Number: 781
get the R's....they just take a beating a keep on going...i've been soo impressed with them.
Username: Nd4spd18
Philadelphia, PA
Post Number: 8891
Out of those two the type R is the better all around sub
Username: Redliner
Wilmington, Ma
Post Number: 4593
I say get kicker cvr's if you want loud and sq since they get louder than type r's. But they still retain some form of sq. or if you can afford them get the kicker cvx's
Username: Insearchofbass
Post Number: 10802
type r
Username: Basssquared
Kansas
Post Number: 2370
L7 hands down
Username: Livin_loud
COD4 Addict
Post Number: 2719
silly Ray, L7's are for noobs!
Kansas
Post Number: 2371
well as far as i'm concerened if you have to ask for help regarding what sub to run in a car audio forum than your a noob so the L7 will fit him nicely ;)
COD4 Addict
Post Number: 2720
lol. well they gotta start somewhere...
i'd suggest going with 2 audioque sdc2.5, over the type arrr's. i think many will agree :-)
ha i want a sub that is loud! but i dont want a loud sub that sounds like crap...
Post Number: 1419
how about an fi q 15 or 18
Amplifier Type - Mono Channel
Bridgable - Not Bridgable
RMS Power at 4 Ohms 600 W x 1
RMS Power at 2 Ohms 1200 W x 1
Post Number: 1420
ya sorry i didnt see your link at the top look into the fi q ficaraudio.com it will get loud with great sq
http://www.dealtime.co.uk/xPF-JBL-BP1200-1
or there is a link
Username: Nd4spd18
Philadelphia, PA
Post Number: 8898
" I say get kicker cvr's if you want loud and sq since they get louder than type r's. "
Umm no.
Username: Tatonka
-[Team Audible
Insanity]-
Post Number: 2442
"I say get kicker cvr's if you want loud and sq since they get louder than type r's."
ROFL! In that case, look for a pair of funky pups over the kickers.
Username: Hittin1
Lake Charles, La.
United States
Post Number: 1574
Type-r's would crush CVR's all day every day. except April 1st.
Username: Rovin
1 15 = 149.5 DBs
Trinidad & T...
Post Number: 14340
do 2 type Rs or 1 15 RE SX ...
Username: Rovin
1 15 = 149.5 DBs
Trinidad & T...
Post Number: 14343
whoa charlie u made mistake there bud - R is a louder better sq sub than cvr anyday but by any means cvr is still decent but R is better for sure ...
what about JL W3s?
COD4 Addict
Post Number: 2729
^ if you want straight sq, go ahead.
Post Number: 7
will it not be as loud as a type r or l7?
COD4 Addict
Post Number: 2732
hell no haha. L7's get pretty loud, type r's get decent dB. it will audibly sound better than both though.
Post Number: 8
so which one would you suggest between the Type R, the L7, or the W3?
Username: Nd4spd18
Philadelphia, PA
Post Number: 8924
R
Username: Ducka
United States
Post Number: 710
R
Username: Turnmat
Racine, Wi
Post Number: 795
R
COD4 Addict
Post Number: 2735
R
Username: 420alldaylong
Post Number: 3846
Out of those go with Alpine Type R's.
Also take a look at RE SE 12's.
Username: Quirky
SA, Texas
Post Number: 333
R
but look around more out of the mainstream or "big store brands" and u will find better quality at the same prices. Some other brands to check out are Fi, RE, RD, audioque, Ascendant audio, Sound splinter, DC.
In my opinion the L7 and L5s have no sound quality but if you were fine with the L5s then its your call.
Username: Lil_justin850
Justin smith, crestview, Fl
Okalossa
Post Number: 24
2 ssd cause that amp is probally a lil overated
Username: Nd4spd18
Philadelphia, PA
Post Number: 8937
That JBL amp is good quality a NOT overrated
you = fail
Username: Goodie_goop
Mid town, Texas
U.S.
Post Number: 1077
i ran a 10" R for awhile...it was cheap and i didnt have any money but it really suprised me...
Username: Blaze87
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
R
Username: Hittin1
Lake Charles, La.
United States
Post Number: 1668
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
r
Username: Purplehase_bong
BC
Post Number: 311
if you want db's then the L7 by all means, in the right ported enclosure you will be doing 146db easy.
A pic is worth
1000 posts!!
Post Number: 19024
rrrrrrrrrrrrrrrrrrrrrrrrr
Post Number: 9
what about the type rs or the jl w3s?
Post Number: 10
and should i get 2ohms or 4ohms with that amp?
Username: Nd4spd18
Philadelphia, PA
Post Number: 9005
Type R will be louder than W3
Get dual 2 ohm
Username: Redliner
Wilmington, Ma
Post Number: 4700
rov i always heard the cvr was louder than the type r and hearing both b4 i would agree. but i bet the r can get louder if u actually know what ur doing
Username: Dmwsolon
L7 our louder i had one. type R are loud but not as loud but alil better on sound quality. Id get the L7 tho as long as u can power it right. get a 15inch
A pic is worth
1000 posts!!
Post Number: 19073
Can't believe after all these recommendations for the R it's still going.
Post Number: 10958
"what about JL W3s?"
w3's are ok but id pass on them. I had a 12 w 3 in my old monte carlo z34. But the w6 v2 12 is much better. Go with that over the w3 for sure.
The 12 w6 v2 has very good sq with average output probably around 132 -135 db with 500 watts in a ported box depending on the vehicle.
Home > Message Board > Car Audio > Subwoofers > Archive through December 05, 2008 > L7s or Type Rs? [ « Previous ] [ Next » ]
