Thread: 15" vs. 2-12" |
Silver Member Username: Teamdeboy1971
OPTIDRIVE LN.,
TN
Major Bass P...
Post Number: 531 Registered: Nov-06
| Posted on Tuesday, November 11, 2008 - 01:56 am: |
Hello I am writing in regaurds to my 19 yr old son! He has a 1995 olds Cutlass Ciera 4 door with a back seat that will not lay down!! I know my son is more of an SPL type of guy you could say, maybe 70/30 SPL over SQ, but here's where we sit? We have a Pioneer HU with a .5 ohm stable Lanzar Opti2000d we were going to maybe go with a sub 300 or under! I thought a 15 would hit a little harder but with the amp we have a single 15 dvc 2x2 won't go to .5 I don't think! 2 -12" optidrives will wire down to .5 and they sound good, we have heard a set before in my car! So, with a trunk set-up will a single 15 hit harder than the 12's???? Thanks, always enjoy your comments! Ps. I had a guy going to sell me a MT RE 15 for 380 shipped on ebay, but you know how that works? I have also ran accross a 15" L7 DVC 2X2 250.00 WITH A 4.0cu ENCLOSER! And a BL 15 FOR UNDER 300! remember he likes SPL so besides getting a new car what can we do??????? HELP!! 15 OR 12X2 |
OPTIDRIVE LN.,
TN
Major Bass P...
Post Number: 532 Registered: Nov-06
| Posted on Tuesday, November 11, 2008 - 01:57 am: |
POSTED TWICE PLEASE TAKE 1 OFF NARRATOR, THANKS |
Silver Member Username: Basebalz13
Moneta,
Va
Usa
Post Number: 804 Registered: Aug-07
| Posted on Tuesday, November 11, 2008 - 11:31 pm: |
i would do 15, better lows, but you can get a dual 1 ohm sub |
Gold Member Username: Livin_loud
COD4 Addict
Post Number: 2731 Registered: Jan-06
| Posted on Tuesday, November 11, 2008 - 11:42 pm: |
"PLEASE TAKE 1 OFF NARRATOR" we have a forum narrator? lmao 2 12's would be more sufficient due to cone area. i'm running 1 15" now from my single 18" and am kind of disappointed... the 15" is much more capable than my 18" was btw |
Gold Member Username: 420alldaylong
Post Number: 3842 Registered: Sep-06
| Posted on Wednesday, November 12, 2008 - 01:33 am: |
http://cgi.ebay.com/2-RE-AUDIO-SE12D2-SE-12-2400w-CAR-SUBWOOFERS-SE12-D2_W0QQite mZ300272846751QQihZ020QQcategoryZ18805QQcmdZViewItemQQ_trksidZp1713.m153.l1262 4cf.@35Hz= Always build box to spec. http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=22 |
OPTIDRIVE LN.,
TN
Major Bass P...
Post Number: 533 Registered: Nov-06
| Posted on Saturday, November 15, 2008 - 02:48 am: |
would these be capable of some pretty good spl???? |
Platinum Member Username: Insearchofbass
Post Number: 10872 Registered: Jun-04
| Posted on Saturday, November 15, 2008 - 09:51 am: |
Here is more along the lines of what your looking for. A audioque hdc 15 dual 1 ohm these subs are rated 1000 rms but can take about 1300 rms easy and will get loud with a 40 hz tune. They are made for that kind of tune but will get lower than that by design. I saw one of these hit 141.9 db on 1000 watts daily tuned. You would set your amp gain with a digital multimeter for the 1300 watts. Go with 4 cubic feet after sub and port tuned to 40 hz. And give the sub 64 cubic inches of port. http://www.audioque.com/aq/HDCSeries.htm http://www.audioque.com/aq/order.htm |
Gold Member Username: Safe_cracker
Only Fcking H0M0S ,
Say WaterPolo!
US
Post Number: 4885 Registered: Jan-06
| Posted on Sunday, November 16, 2008 - 06:08 pm: |
Also need to ask yourself do you really want to run any Lanzar at .5ohm daily? Probably not. Polo.. |
Gold Member Username: Nd4spd18
Philadelphia,
PA
Post Number: 8967 Registered: Jul-06
| Posted on Sunday, November 16, 2008 - 10:21 pm: |
Two 12"s has the potential to be louder, due to more cone area. |
