Home > Message Board > Car Audio > Amplifiers > JL Audio hd 500w amp
Author Thread: JL Audio hd 500w amp
Username: Shanky
Orange
I am getting the jl audio 10" w3v3 it has 1000w and the max is 500w rms and I am thinking of getting the "jl audio hd 500w amp" but I do t know if that's the right watts to put in there
Username: N2audio
Lawrence, Ks
Post Number: 1673
There are three versions of that sub - 2 ohm, 4 ohm, and 8 ohm. We need to know which you are getting to know what amp would work best. The 2 ohm or 4 ohm version would work well with the 500/1, but there are a lot of other less expensive options for quality amps that will do a good job.
Username: Shanky
Orange
it's the 2 ohm
Username: N2audio
Lawrence, Ks
Post Number: 1677
The JL would work well, but it's pretty pricey. It will cost you in the neighborhood of $450.
For around $200 you can get something comparable power-wise from a number of quality brands -- Alpine, JBL, Infinity, Pioneer, MTX etc.
Username: 420alldaylong
Post Number: 3841
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=475
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Amplifiers > JL Audio hd 500w amp [ « Previous ] [ Next » ]
