Thread: Need help on first system PLEASE!!!!!! |
Bronze Member Username: Dragon_kid
Oxford England
Post Number: 17 Registered: Nov-08
| Posted on Sunday, November 16, 2008 - 07:50 am: |
so far i think i know what i want but here is what i come up with subs: 2 15" kickers solobaric 2008 model amplifier: kicker ZX 2500.1 ( taking suggestion on improving ) 4 6×9: all 4 diamond D393i ( taking Suggestion for better sq ) new alternator 1 extra batt: not sure on what type i need to power channel amplifier: not sure need something to power cd player and speakers dash cd player: no clue looking one around 200 - 300 dollars pioneer cap: no clue but look to get a 5 farad please rate out of 10 and on how many db i well pump out of this all improvements welcome please a thanks |
Gold Member Username: Surferdude9371
Get loud or go home....
Post Number: 1441 Registered: Mar-07
| Posted on Sunday, November 16, 2008 - 09:14 am: |
if you want dbs up the two solobarics to one fi btl fully loaded ficaraudio.com and run that off the kx2500.1 for comps diamond is ok if you have the cash bump up to some cdt audios. head unit pioneers are having issues with there rcas id go with alpine and DONT GET A CAP they are usless and will only put a strain on your charging system buy a 200+ amp alt and an extra bat |
Oxford England
Post Number: 18 Registered: Nov-08
| Posted on Sunday, November 16, 2008 - 09:26 am: |
i can't get the fi btl the company don't ship to the uk also is cdt better then diamond by alot?? |
Post Number: 1442 Registered: Mar-07
| Posted on Sunday, November 16, 2008 - 09:56 am: |
dd 9915 cdt is alot better but alot more exp |
Platinum Member Username: Insearchofbass
Post Number: 10876 Registered: Jun-04
| Posted on Sunday, November 16, 2008 - 10:43 am: |
eclipse 3100 5 volt preout. Great cd player. I own one 129.99 shipped. http://www.crutchfield.com/App/Product/Item/Main.aspx?search=eclipse+3100&i=099C D3100 |
Gold Member Username: Loudon
Post Number: 2817 Registered: Jun-04
| Posted on Sunday, November 16, 2008 - 11:45 am: |
i wouldnt necessarily say cdt is better then diamond .. if he is getting the hex series ... those things take a butt load of power and sound great thats a great HU for 130 bucks .. pretty much unbeatable i look into a pair of 3500s ... and run em off that zx2500 .. i personally dont like the 9515 but its preference ... but good luck with it man.. make sure u factor in enclosure.. wires... install if u cant do it urself |
Post Number: 1443 Registered: Mar-07
| Posted on Sunday, November 16, 2008 - 11:52 am: |
either way 9500 or 3500 DD will kill kickers subs anyday with sq and output with the 9500 series |
Gold Member Username: Redliner
Wilmington,
Ma
Post Number: 4661 Registered: Jun-05
| Posted on Sunday, November 16, 2008 - 12:56 pm: |
"DONT GET A CAP they are usless and will only put a strain on your charging system" he said above he was going to get a new alt and a battery. If he wants to get a cap after those its fine it smoothes out the little drops you have since a cap is faster than a battery or alt. It has power stored up and can discharge at a fascinating level. They do, do good things if you put them in for the right applications. Only if u have the power to supply though. |
Wilmington,
Ma
Post Number: 4662 Registered: Jun-05
| Posted on Sunday, November 16, 2008 - 12:59 pm: |
http://www.soundpressure.com/ also if u want dd look into this site. its there forum and its based in europe so check it out |
Oxford England
Post Number: 19 Registered: Nov-08
| Posted on Sunday, November 16, 2008 - 02:11 pm: |
well guy i'm really trying to beat rockford fosgate subs that my m8 has got and i still want the sq to be clear also is it a good thing to get a sound processer |
Oxford England
Post Number: 20 Registered: Nov-08
| Posted on Monday, November 17, 2008 - 03:42 pm: |
please help more info needed |
Gold Member Username: 420alldaylong
Post Number: 3861 Registered: Sep-06
| Posted on Monday, November 17, 2008 - 05:43 pm: |
What RF subs does your m8 have? What amp is your m8 using on those RF subs? Install is very important. |
Oxford England
Post Number: 23 Registered: Nov-08
| Posted on Thursday, November 20, 2008 - 08:03 pm: |
he has RF t1s and the make of his amp is spl dynamic not sure what type of amp i just the name of make |
Gold Member Username: Hittin1
Lake Charles,
La.
United States
Post Number: 1690 Registered: May-07
| Posted on Thursday, November 20, 2008 - 08:30 pm: |
A CDT comp set is much better than the coaxial 6x9's.. The Eclipse H.U. is a great buy. Dont worry about the Cap. Not needed. Aq3500.1 sub amp. or Kicker Zx2500.1 2- Audiopulse Revo's/ V.C. depends on amp selection 250 amp alt Kenetic 2400 in rear whatever Kenetic that you can fit in front a good comp set for frontstage (maybe diamond hex) MRP-F600 bridged for the comps There are many other ways you could go but this would likely be better than your m8.(install considering.) |
