Home > Message Board > Car Audio > Amplifiers > What amp for 4 L7 15'?
Author Thread: What amp for 4 L7 15'?
Username: Whiteblaster
Post Number: 14
what amp / or amps should i get?
do NOT want to UNDERpower!!!
looking for the perfect amount of juice for these babies, and ideas?
Username: Deusle
2 hifonics BXI2006D's
or 4 kicker ZX1000.1's
whats your electrical system look like?
Post Number: 15
nothing yet lol, im orderng everything soon, and dont know much about wattage
all i have is an optima yellow capper
i know ill need alt and stuff
but would those 2 hifonics work? isnt that to small?
would a zx2500.1 work
Post Number: 16
nvrmd scratch that i guess i can only afford 3
Username: 420alldaylong
Post Number: 3856
3 what?
Username: Nd4spd18
Philadelphia, PA
Post Number: 8963
If you didn't buy the subs yet don't. L7s suck. (sound quality and build quality)
Username: Shak180
Hayward, California
Usa
Post Number: 171
L7's look cool though
Post Number: 18
lol i just had a big argument in the sub section about which ones to buy, but these are the cheapest loudest squares i found and they dont need 4 batteries and a ton of electrical upgrades
3 2008 Kicker 15' l7's
Username: Bonhamd
Post Number: 1469
thats bull shiit
to properly run those subs you will need electrical upgrades
did you get a car yet?
why dont you just listen to us?
Username: N2audio
Lawrence, Ks
Post Number: 1688
If you're looking to run 2000w+ and run it at or near full volume once in a while you'll want, at the minimum a big /-\$$ alternator.
200A or so. One good healthy battery will suffice unless you want to run it (loud) without the engine running more than a couple minutes at a time.
And I think if you ask around you'll find a LOT of people that would adamantly argue M.S.'s opinion on L7's.
Username: Rovin
1 15 = 149.5 DBs
Trinidad & T...
Post Number: 14400
y does any1 really 'want\need' 4 15s ...
Username: Bonhamd
Post Number: 1470
i dont think L7s are bad at all - i have owned 3 different L7 15s
i am just saying that i think he can do better than L7s with his budget
Post Number: 3865
I bet you would love 1 good 15" on 1000RMS.
Username: Insearchofbass
Post Number: 10885
Perhaps a audioque hdc 15 or 18 on 1200 watts. dual 2 ohm
audioque 1200d 1200 at 1 ohm for $249
http://www.audioque.com/aq/HDCSeries.htm
http://www.audioque.com/aq/order.htm
Username: Somedonniedude
Illinois
Braaap MX
Post Number: 2097
An L7 would sound fine on rap or similair music. But on rock or anything with true instruments, they sound like poo. Atlest the 15"s do...
Post Number: 19
well the rock and rapi kisten to allhit in my car, and i got two little brutus squares, and my buddys l7's beat the crap outa my sub
Username: Blaze87
they will get loud dont get me wrong we carry them, but why not get a sub that gets loud, and still sound good on all types of music?
the hifonics squares? thats not even a sub in my book, spl or sq, jmo
fi-bl
aq-hdc3
alpine-typer
jl-w7, many more
but, then, what is your budget?
Post Number: 20
ok i dont want everyone in the forum yelling at me again for this, my budget is 2k for subs and an amp, all electrical and everything seperate
I am in the process of choosing an suv type vehicle, and am not decided on the honda cr - v, or jeep grand cherokee, chevy trailblazer, or some others in mind
ive heard the type r's, and i mean their LOUD, but i never really felt them in the dudes car
and dude you really shouildn't diss thos brutus squares, they slam pretty hard for only 120 bux a pop, they just dont hit real high or low low, but it was my first system, and those things shook every part of my 95 grand am off, and are in the process of destroying a 2002 grand prix se
anyways, i keep finding and losing the site, but i have a LEGITAMATE kicker dealer that wil sell me 4 2008 kicker l7 15' subs for 900 bux w/sh
i also found a legitamite site that i can get the 2008 zx 2500 for 800 bux
i was wondering if that would be enough to power all four safely, an not underpower?
i will have two yellow capper optima batteries, and il end uip getin a cap and alt soon after the order
Username: Bonhamd
Post Number: 1507
so are you dead set on a SUV atleast? the vehicle is an important factor in choosing sub sizes due to the air space
you can get some really good deals on RD Audio at the moment
http://forum.ecoustics.com/bbs/messages/4/529468.html
Username: Toyotwincamgt
Arroyo, Puerto Rico
United States
Post Number: 10
brutus is a little overrated u need roford fosgate
Post Number: 21
what are you talkin about dude?
i was just mentioning my 12' square HIFONCS BRUTUS SUBWOOFERS
i wasnt referencing amps
but yes i am dead set on an suv or extendeed truck
and would the zx 2500.1 powwer um perfect or do i need more?
Username: Hittin1
Lake Charles, La.
United States
Post Number: 1718
the L7's would work on that power. but really need more than that for 4 -15's.
I would do a minimum of 3500wrms.. maybe AQ3500, or rd 3250 @.5ohm. . Maybe you can find a used Ia40.1. RF Tpower 4k(cant believe i said that), or equivalent.
Seriously.. get the AQ HDC3 15's. with 4 of em you will forget all about what coulda been with the squares.
<----been there - done that- moved on
Username: Beatin_down_yo_block
Okalhoma City, Oklahoma
United States
Post Number: 35
ok check out onlinecarstereo.com, save money go with 4 kicker L7 and get 2 1500 watt Kicker amps..
Username: Nd4spd18
Philadelphia, PA
Post Number: 9227
Or you could not buy shitty sounding square subs
Username: Joshualittle
Columbus, Ohio
United states
Post Number: 8
Bro with a budget like that I'd be looking elswhere for subs and amps, I can get you a deal on arc audio amps, hertz subs, you name it. For $2000 you can have a hell of a system. Why not 2 arc audio ks 1000.1's and 4 jl audio 12 w6's, well below your budget, I can get the amps for about $400 a piece, woofersetc.com wants $550 for them and dealer cost stereo, just go to caraudio.com and scroll down and you'll see it. They only want $279 shipped each for the jl audio 12 w6v2d-4's, I would highly recommend those. It'll slam and sound great, if you need any help with pricing e-mail me at joshualittle1982@yahoo.com and I'll be sure to refer you to someone who can help you out. I know you want the best for your money.
Columbus, Ohio
United states
Post Number: 11
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=6865. I would recommend 2 of these amps, a friend of mine can get them for around $400 a piece. And I would go for 4 of these subs.http://www.dealercostcaraudio.com/12w6v2.aspx. Please whatever you do don't go with the square's, I've heard them and while there loud, the sq sucks big hairy balls. If your interested in the amps at around $400 a piece email me at joshualittle1982@yahoo.com
Username: Hittin1
Lake Charles, La.
United States
Post Number: 1969
R.I.P. Ecoustics
Username: Snowball123
West Allis, WI
Post Number: 1868
true that. there is some shi*ty advice in this thread.
Username: Hittin1
Lake Charles, La.
United States
Post Number: 1980
agreed, just about every post but the posts from the regulars.. as far
as l7's nolt needing a bunch or upograds, well..... With 2 L7's on recomended power you would need upgrades... Even moreso with 4.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Amplifiers > What amp for 4 L7 15'? [ « Previous ] [ Next » ]
