Home > Message Board > Car Audio > Subwoofers > Archive through November 23, 2008 > MTX vs Alpine vs Exile
Author Thread: MTX vs Alpine vs Exile
Username: Subbin
I wanted to buy one 12" sub for my benz. I don't no that much about subs but i have narrowed it down to these three. My budget is 250/ea or under, I can get these subs for the low.
1.MTX Thunder 712
Power Handling Max 1200 Watts Max
Power Handling Nominal 400 Watts
Surround Material Rubber
Voice Coil Size 2 3/8 in
Basket Material Cast
Binding Posts Chrome Push Terminals
Cone Material Expanded Poly
Frequency Response 47-150 Hz
Impedance 4 Ohms
Magnet Weight 93
2.Alpine Type R's
Power Handling Max 1500w
Power Handling Nominal 500w
Basket Material Aluminum
Binding Posts Yes
Cone Material Kevlar-Reinforced Pulp
Frequency Response 23Hz-500Hz
Impedance 2+2ohms
Magnet Weight 109 oz.
Mounting Depth 7.7"
Ported Box Volume 0.75-1.75 cu.Ft.
Sealed Box Volume 0.7-1.0 cu.Ft.
Sensitivity 85dB
Surround Material HAMR
Voice Coil Size 2"
3.Exile Pro Series(XPe subwoofer)
Power Handling Max 1000 Watts
Power Handling Nominal 500 Watts
Binding Posts Spring Loaded Nick Plated Terminals
Cone Material Poly
Frequency Response 23Hz - 117Hz
Impedance 4 Ohms
Magnet Weight 10.69 kg
Mounting Depth 6.8"
Ported Box Volume 1.6 ft/3
Sealed Box Volume 0.75 ft/3
Sensitivity 89dB
Voice Coil Size 2.5"
You guys tell me because you guys probably know more than be Im going more to the Alpine Type R's
Username: Hittin1
Lake Charles, La.
United States
Post Number: 1614
Type R would be an easy choice for me.
Username: Mrskullz1
Brooklyn, New York
Post Number: 922
do they have to be only those 3 subs? if you list your budget on the total system...you will get a lot more help. There are much better products out there than those listed above
Username: Subbin
My budget is 250/ea or under, I can get those subs for the low
Username: Cozce
St. Louis ILLside
U.S.A.
Post Number: 374
Mach5 IXL 12? $195
Username: Subbin
I for got to state im getting them from best buy / future shop (canada) and these are they only good ones they have unless some one has a legit website were i can get better subs from and the name of the sub
Username: The_image_dynamic
San Diego, California
Post Number: 4764
Exile
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 3424
Exile>Alpine>MTX..
Cant go wrong with the alpine or exile, but the MTX looks pretty weak.
Username: Basebalz13
Moneta, Va
Usa
Post Number: 819
agreed son
Username: 420alldaylong
Post Number: 3867
Alpine/Exile
How much are you paying for the subs?
Username: Subbin
Im getting them on a staff discount basically half price from there original price.
Username: Subbin
Post Number: 7
i thought alpine type R will probably dominant because i never hear much about exile
Post Number: 4768
Exile is an excellent new company started by two engineer/designers from Phoenix Gold.
Home > Message Board > Car Audio > Subwoofers > Archive through November 23, 2008 > MTX vs Alpine vs Exile [ « Previous ] [ Next » ]
