Home > Message Board > Car Audio > Subwoofers > Archive through November 23, 2008 > Need some help on some gauges
Author Thread: Need some help on some gauges
Username: Basebalz13
Moneta, Va
Usa
Post Number: 813
need some help looking for some amp temp gauge, and current draw, and volt gauge, all the matching thats the catch
Username: Wickedbass
Nashville, Tn
Post Number: 113
As far as gauges go autometer FTW!!!
Here you go man:
Amp temp:
http://www.autometer.com/cat_gaugedetail.aspx?ref=search&gid=2565
Current draw:
http://www.autometer.com/cat_gaugedetail.aspx?ref=search&gid=2564
Voltmeter:
http://www.autometer.com/cat_gaugedetail.aspx?ref=search&gid=2566
All matching Autometer Cobalt series.
Moneta, Va
Usa
Post Number: 815
yeah but the prices not soo good, i need 4 each lol
Moneta, Va
Usa
Post Number: 816
the temp is 112, current is 173, n volt i think 89
Nashville, Tn
Post Number: 114
Here are some Cyberdyne gauges, $53 each.
http://www.jegs.com/p/Cyberdyne/759759/10002/-1
Voltmeter, Ammeter and amp temp gauges all matching for cheap...tough bill to fill there bud.
Hope this helps man and good luck with it.
Moneta, Va
Usa
Post Number: 818
thanks an thats alot better, they good gauges still? and i didnt see the current gauge
Username: Nd4spd18
Philadelphia, PA
Post Number: 8971
Go with autometer they are very good quality....... what ever your get make sure the ammeter uses a hall effect sensor so that the power wire doesn't have to run through the gauge.
Moneta, Va
Usa
Post Number: 821
M.S. send me a
im please
Home > Message Board > Car Audio > Subwoofers > Archive through November 23, 2008 > Need some help on some gauges [ « Previous ] [ Next » ]
